Go to Post The whole idea of a robot competition is geared around spectators. Take that away and you have a science fair. - Chris is me [more]
Unread 30-01-2014, 21:51
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Re: Window Motor will not lift ball anymore. It did, but it wont any more.
Originally Posted by nicholsjj View Post
This is added to them as a saftey feature so that children or adults do not break their fingers in a jamed car window I think.
The breaker was added to stop the finger breakage, the locking pins mean a thief cant just force the window down. When its not powered, they are locked.
2014- 5031 Mentor
2013- 1310 Mentor
2012- 4258 Mentor
2011-2012 865 Mentor
2006-2008 1814 Team Captain, Main Driver, Mechanical
Unread 30-01-2014, 21:57
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
Also, is the indicator light on your Spike changing color when you attempt to move it?
Could be a loose/bad/wrong way PWM, program change, etc. If the indicator is turning red/green, then you know the relay is working.
Unread 30-01-2014, 23:28
Ladiesman217 Ladiesman217 is offline
FRC #3965
Ladiesman217 is an unknown quantity at this point
Could you maybe reduce the stress by putting a window motor on both sides of the arms? I would think using 2 window motors would help a lot, but i might be mistaken.
Unread 31-01-2014, 00:11
Doubling up window motors might end up with a worse problem. If one of them runs just a little faster than the other, they'll start fighting each other, and the anti-backdrive feature is likely to lock one of them up. If you don't need the motors to actively hold their position against a force trying to move them, it might be best to open them up and remove the pins.
This application probably calls for a stronger motor, though. It's a good opportunity to do the math and find out what torque is required at what speed, then match that to an available motor and gearbox.
Unread 31-01-2014, 00:12
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Try using a PG motor or a versa planetary.....Window motors are that good
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
I would agree that the single window motor isn't going to work. Looking here, the stall torque of your motor is 94 inch pounds. I'd conservatively estimate you are trying to move 4 pounds with a 2.5 foot arm. This will apply 120 inch pounds. You simply need more power.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 31-01-2014, 00:55
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Originally Posted by ShaneKent253 View Post
Hello from team 253!
We have a window motor lifting a claw that extends out of our frame roughly 19". Last week it worked fine running directly off of a spike and now we just cant get the claw to lift even though we haven't changed a single thing.
I don't know what to do and I am feeling a lot of stress about the situation. Any help would be appreciated.
Thank you!
Shane
Pictures coming.
If you like this design, you could mount an additional window motor to the other side of the arm and wire "backwards" to the first one, so they are both working together. We used the same kind of system to push the bridge down in 2012.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 31-01-2014, 03:56
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
IN 2011, we used a double window motor setup, but had them coupled together via a shaft to ensure they ran at the same speed when moving our arm.
Given the amount of COTS options compared to several years ago, however, we will never use them again for a similar purpose because it doesnt backdrive after a match.
If OP is set on using a window motor, put a reduction AND use another window motor.
Unread 31-01-2014, 08:26
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
No matter what motor you end up using, the first thing you can do to help yourselves is to add a spring to counter balance the weight of your arm. This could be as simple as a piece of surgical tubing wrapped around a pulley that's attached to your arm pivot axis. Attach the other end of the surgical tubing to your frame so that the weight of the arm is supported by the stretched tubing, not your motor. Then, the motor just has to handle arm motion, not carry the weight.
Properly counterbalanced, a window motor just MIGHT work. But, the teams at our last FRC summit concluded that window motors are supplied as object lessons for rookie teams to learn what NOT to use. Most of us just throw them in the trash. With their limited capabilities, there are much better options available. Not to mention that the thermal cutoff will kick in at the most inopportune moment, leaving you motionless until the motor cools down.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 31-01-2014, 08:42
To remind everyone, the locking pins in these motors are really only an issue when driven by Jaguars. There is a lot of discussion about this in the files. It was first brought to our attention by John Novak from Team 16.
I like Todd's suggestion, so you can check if the motor is defective or just being asked to do too much (which we all suspect now that we have seen the assembly). The motor does have a thermal cutout (a PTC as I remember) but that is usually backed up by a hot motor casing.
Unread 31-01-2014, 09:18
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
A window motor is just not going to get the job done here. You are experiencing what happens when you try direct drive. But if you gear it down it will be too slow to shoot the ball.
If you look at the motor data sheet for this year you will find that the window motor is comparatively low power.
You need to find a different basic way to operate your arm using a more powerful motor.
Unread 31-01-2014, 10:05
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by luckof13 View Post
The window motor has an internal thermal breaker in it which opens to prevent the motor from burning out. It appears that you have the motor attached directly to the pivot of the arm. This will place a large load on the motor. When the ball is added, the motor stalls, and the internal breaker trips.
Try using a different motor, and using a gear/chain/belt reduction before the arm.
And the internal thermal breaker gets weaker over time it seems, at least in my/my team's experience with them. If they trip a few times you best be replacing that motor soon.
Originally Posted by Chris is me View Post
You definitely can't get away with directly driving an arm with a window motor. You need a reduction of some kind.
If you can make pneumatics work for you, I would suggest that simply because it's much easier to accomplish and simpler than a motor driven arm system.
I agree, penumatics are a great way to do simple 2-position mechanism actuation.
The window motor's max output is 23W, with is quite a bummer considering there are only a few motors weaker than it, and most motors are a LOT more powerful: http://www.usfirst.org/sites/default...nformation.pdf
Like others have mentioned, it would be a really good idea to use a better/bigger motor.
Unread 31-01-2014, 11:11
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Can't believe it took this long to suggest this. This is a great method to reduce the load on any motor, and the worm-drive mechanism in the window motor is a great way to sidestep any backdriving issues caused by changes in the spring force as your arm travels.
I disagree that they're useless. There are plenty of low-load applications where window motors work just fine, and their worm gear reduction offers a great deal of resistance to backdriving (which is often very useful). Rather than heavily reduce a high power 500-series motor for a low-speed, low-power application, we often use window motors. In 2012, we used a window motor to power our final stage roller, that would load the balls into our shooting wheels. Not much speed or power required, and with a tight compression, high CoF, and the worm gear combined, we prevented ourselves from "accidentally" shooting a ball early when the loader stacked up. In 2013, our original loading cam was powered by a window motor as well, but this entire loading mechanism was eventually replaced by a pneumatic system.
Don't take that to mean that the window motor is the correct choice for this application, though.
The throttle motors, on the other hand....
Unread 31-01-2014, 11:30
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I completely agree with Mr. Lavery about the window motors not being useless. We have certainly burned out our fair share of them when we were stretching their capabilities, but in the correct applications they can be very useful. The hubs alone can make them useful for some applications, as they are easy to mount things to without significant machining capabilities. Add the worm gear and they can be used in a variety of ways, as long as you aren't trying to put too much load on them. As Mr. Ferrante said, counterbalancing the load with a spring of some sort can help a lot. Here is an application of this sort of counterbalancing.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
