Go to Post ..attitude and willingness to work as a team...are the qualities that can make or break a team. - Monochron [more]
Unread 31-01-2014, 09:38
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Help with Prototyping Board
Every year we get into a situation where we need to speed-control a motor in some prototyping system and I always say I'm going to build some simple control circuit. I have limited electronics knowledge (enough to be dangerous) and I have found a simple circuit called: "Square Wave Signal Generator with Pulse Width Modulation". The circuit
http://www.rmcybernetics.com/project...generator2.htm
allows variable control of the frequency (which I understand needs to be 15kHz for controlling a Jaguar) and the pulse width.
Will this do what we need? (By that, I mean, can we connect the Jaguar pwm input to this generator and control motor speed without needing our control system?)
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 31-01-2014, 12:21
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Re: Help with Prototyping Board
I ran into the same need on our team. My solution was to just pick up an RC servo tester. HobbyKing carries a bunch of them: http://hobbyking.com/hobbyking/store...h=servo+tester
These will cable right to the speed controller via the PWM port. I just got a cheap one and powered it via a 3S lipo and a UBEC that I had laying around, but some of the better ones have more power options.
Unread 31-01-2014, 12:32
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Originally Posted by ILAMtitan View Post
I ran into the same need on our team. My solution was to just pick up an RC servo tester...
...I just got a cheap one and powered it via a 3S lipo and a UBEC that I had laying around, but some of the better ones have more power options.
What is a "3S Lipo" and / or a "UBEC"
Can I not just create 5VDC from a stock adapter, or from a bank of batteries?
Unread 31-01-2014, 12:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
For prototyping purposes, we took apart an old drill and refitting things. Basically, a battery connector goes in the butt, and two wires with some quick connect fittings come out the top. Then it's just a matter of plugging it into a battery and the motor, and you have instant, easy to use speed control.
2016: Lake Superior WFFA
Unread 31-01-2014, 12:54
The Jaguar PWM input is not 15khz. The input PWM is defined in the Jaguar Datasheet, available from VexPro (it's called servo style speed input).
3S Lipo is a Lithium Polymer battery popular with RC hobbyists. Use a Robot Battery instead. UBEC is a Universal Battery Eliminator Circuit, in other words, a 5v converter.
If you want to buy, like ILAMtitan said, you can find many options at any hobby shop (usually called a servo tester). If you want to support FIRST vendors, here are a few other options, with varying capabilities.
http://www.andymark.com/product-p/am-2732.htm
http://www.andymark.com/product-p/am-2503.htm
http://robotlogic.com/wp/product/servo-tester/
Several people have posted circuits on chiefdelphi. I've never seen one with a 555 and a comparator, I usually see them with 2 555s. You could even use a really old computer: http://www.chiefdelphi.com/media/papers/2702
Unread 31-01-2014, 15:09
Texas Instruments
AKA: Bart Basile
Sorry for not clarifying, I come from the RC world where these are standard terms. A 3S LiPo is a lithium polymer battery pack containing three cells in series. Each cell is 3.7V, so the whole thing outputs a nominal 11.1V. There are also other cell count varieties, and I've seen up to 11S which would be 40.7V.
A UBEC is really just a highly efficient voltage regulator. It takes a voltage input above 6V, and drops it down to 5V. So the 3S battery connects to the UBEC input, and the output is 5V. This 5V is the standard TTL value used in servos and motor control systems. I used this one becouse it's cheap and I didn't need much current: http://hobbyking.com/hobbyking/store...BEC_3A_5v.html
I actually don't recommend the LiPos if you aren't familiar with them. They require highly specialized chargers and can be very dangerous is mistreated. A better battery option would probably be a cheep 4x AA holder. This would give you enough voltage to power the UBEC and feed into the tester and subsequently your servo or motor controller.
This is of course the low cost cobbled together way to do this. If you can spend a bit more, the two AndyMark products that Joe Ross linked will be much easier to us, and likely provide more features.
Unread 31-01-2014, 15:50
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Thanks everyone for all the information. I managed to find an inexpensive servo tester on ebay that will ship and arrive quickly. I would have preferred to find something that I could have bought or built from local sources so I could have it immediately - but the closest reliable source for RC stuff is about an hour drive.
While I'm waiting for that to arrive - I'll tackle the 5V power situation. Ideally, I'd like to create something that uses the same 12V robot battery that we will be using to power the motor on the other side of the jag, or some old power supply I have sitting around from an old laptop or something. I think my "enough to be dangerous" electronics can handle getting 5V out of something we have available.
Thanks again!
Unread 31-01-2014, 16:09
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
While they nominally output 11.1V, they are charged up to 12.6V, or 4.2V per cell, and then drop down to around 9V at a minimum or else you probably damaged the battery. So really a robot battery will be a very similar replacement.
Just that the robot battery wont catch fire if you drop it the wrong way. Those LiPos pack quite a punch.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 31-01-2014, 17:50
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Can I use the 12V-5V power converter that we use for the radio on the robot? We have a couple of those laying around.
If the answer is no (which I suspect it's going to be) please tell me why - in Math Teacher language - not EE language.
Unread 31-01-2014, 18:04
Yes, or in math teacher language possibly "1"
Unread 01-02-2014, 11:54
If you have an old laptop, all you need is this software.
Unread 01-02-2014, 21:11
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
We use arduinos to run our motors. I have read about others wanting to do this so our team is going to post the code on our site when our members get a chance. I fyou want our code PM me.
Unread 01-02-2014, 21:14
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
We do the same thing, and it's insanely useful.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 01-02-2014, 21:43
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Thanks both of you:
I looked at that information before I posted and my head started to spin. It looked like the kind of thing I would spend two days working on and have nothing happen as a result!
Originally Posted by amesmich View Post
We use arduinos to run our motors. I have read about others wanting to do this so our team is going to post the code on our site when our members get a chance. If you want our code PM me.
We have no one on our team with any expertise in arduino use. Learning this is on my to do list - but there's a bunch of stuff higher on the list...I needed a more immediate solution. I may take you up on that AFTER the build season.
Every year we get into a situation where we need to speed-control a motor in some prototyping system...
Here's Team 610's solution:
Originally Posted by Mr. Lim View Post
I find the true strength of Jaguars to be during the prototyping phase. They are the best for getting a quick PID system running within a matter of minutes. A Jag, battery, encoder/pot, a laptop w/ black serial adapter and BDC-Comm. They were game changers for us in 2013 when we had several frisbee shooting prototypes, and were able to put very good closed loop control on each and every one.
