Go to Post Duct tape is like the Force - it has a dark side and a light side and it holds the universe together. - Jnadke [more]
Unread 25-01-2014, 13:54
Silver's Avatar
Silver Silver is offline
Rookie
AKA: Digby Baker-Porazinski
FRC #5236 (Man O' War)
Team Role: Tactician
Silver will become famous soon enough
Lightbulb Connecting Camera to RoboRealm via D-Link
Hey all. Silver here.
Our team has encountered a situation where we are attempting to establish a camera for the first time. We want our Axis camera to be wired to our D-Link, which is wireless from the computer, then for the camera to appear in RoboRealm. We have successfully gotten the camera to show up in SmartDashboard, but cannot get it to show up in RoboRealm. Any help, links or tutorials would be greatly appreciated.
Thanks again.
Unread 25-01-2014, 16:46
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Connecting Camera to RoboRealm via D-Link
To get a connection in RoboRealm, you have to use the Read_HTTP module, which is under Loading/Saving. Add that, then edit its settings. Type in the URL of your camera's .mjpg file (the Camera Type box should get everything right but the camera's actual IP.) Then click Start. That should do it!
If it still doesn't work, try closing SmartDashboard - I've found that only one program can access the camera stream at once.
Unread 28-01-2014, 19:51
Silver's Avatar
Rookie
Much appreciated. Our programmer tried this out and (after a bit of struggling) figured it out and we're all set up. Thanks!
Unread 29-01-2014, 11:24
bvisness's Avatar
Awesome, glad it worked. Also, it turns out I lied about only one program accessing the camera at a time - SmartDashboard and RoboRealm can access the feed simultaneously, no problem.
Unread 29-01-2014, 20:12
yash101 yash101 is offline
AKA: null
The MJPG stream is: http://[camIP]/mjpg/video.mjpg
You may want to disable viewing authentication. It caused some problems with OpenCV for me, so it may cause problems in RoboRealm
Unread 31-01-2014, 13:23
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
All you need to do to use the axis camera stream is to use the "Axis Camera" module in Roborealm. It works perfectly for my team.
