Re: Help with Prototyping Board
A UBEC is really just a highly efficient voltage regulator. It takes a voltage input above 6V, and drops it down to 5V. So the 3S battery connects to the UBEC input, and the output is 5V. This 5V is the standard TTL value used in servos and motor control systems. I used this one becouse it's cheap and I didn't need much current: http://hobbyking.com/hobbyking/store...BEC_3A_5v.html I actually don't recommend the LiPos if you aren't familiar with them. They require highly specialized chargers and can be very dangerous is mistreated. A better battery option would probably be a cheep 4x AA holder. This would give you enough voltage to power the UBEC and feed into the tester and subsequently your servo or motor controller. This is of course the low cost cobbled together way to do this. If you can spend a bit more, the two AndyMark products that Joe Ross linked will be much easier to us, and likely provide more features. |
Thanks everyone for all the information. I managed to find an inexpensive servo tester on ebay that will ship and arrive quickly. I would have preferred to find something that I could have bought or built from local sources so I could have it immediately - but the closest reliable source for RC stuff is about an hour drive.
While I'm waiting for that to arrive - I'll tackle the 5V power situation. Ideally, I'd like to create something that uses the same 12V robot battery that we will be using to power the motor on the other side of the jag, or some old power supply I have sitting around from an old laptop or something. I think my "enough to be dangerous" electronics can handle getting 5V out of something we have available. Thanks again! |
Just that the robot battery wont catch fire if you drop it the wrong way. Those LiPos pack quite a punch. Last edited by dellagd : 31-01-2014 at 16:12. |
Can I use the 12V-5V power converter that we use for the radio on the robot? We have a couple of those laying around.
If the answer is no (which I suspect it's going to be) please tell me why - in Math Teacher language - not EE language. |
Yes, or in math teacher language possibly "1"
