Go to Post Robots will consume you if you are not careful. - JohnBoucher [more]
Unread 30-01-2014, 17:14
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Help A Brotha Out. Error 44002 and 44004.
What mode are you placing the robot in through the driverstation to run your test, Autonomous Teleop Practice or Test?
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 30-01-2014, 18:34
SpaceCows SpaceCows is offline
FRC #5202
SpaceCows is an unknown quantity at this point
We have tried all of them and receive the same result of nothing.
Unread 30-01-2014, 19:32
sukhjinder564's Avatar
sukhjinder564 sukhjinder564 is offline
FRC #0564
sukhjinder564 is an unknown quantity at this point
I would recommend simplifying the operator control for now.
I have never used the Timer function in teleop, so this timer may be throwing your code off, but if the code is not being reached, make sure the conditions of the while loop are being satisfied. Or you could just remove the while loop entirely and see how that works.
This may or may not work for SimpleRobot, as I always use IterativeRobot.
Does the operatorControl() function run periodically?
Unread 30-01-2014, 21:21
Originally Posted by SpaceCows View Post
We are experiencing error codes 44002 and 44004...
Warning <Code> 44002 occurred at Ping Results:  link-bad,  DS radio(.4)-bad,  robot radio(.1)-bad,  cRIO(.2)-bad,  FMS-bad Driver Station
<time>1/30/2014 1:45:09 PM<unique#>51
FRC:  Driver Station ping status has changed.
Warning <Code> 44004 occurred at Driver Station
<time>1/30/2014 1:45:07 PM<unique#>50
FRC:  The Driver Station has lost communication with the robot.
I know you've corrected the IP address problem, but I wanted to point out that those codes aren't actually errors. They're only warnings, and in many cases they just verify that the network connection is functioning as expected. (In your specific case, they actually verify that there is no network connection at all.)
So now you're getting no response from your motors? That could be the fault of a great many things. To start narrowing them down, look at some of the many status lights on your robot. When you're trying to move the motors, what are the lights on your motor controllers doing? What is the big orange Robot Signal Light doing?
Unread 31-01-2014, 14:51
FRC #5202
I'm thinking that no functions are ever reached. I removed both the timer and the while loop, both getting no results. I got this message in the console: [cRIO] Default disabled() method running, consider providing your own. I created a disabled() method in the code and I still received the same message.
Also my Jaguar motors just constantly blink yellow and my Robot Signal Light continuously blinks when the driver station is off, but it starts to change its blink pattern when I change the operation modes in the driver station.
Unread 31-01-2014, 14:59
That is appropriate advice for IterativeRobot, but not SimpleRobot. In simpleRobot, operatorControl is called once. It is the users responsibility to provide a while loop and to provide a delay (to avoid pegging the CPU).
Unread 31-01-2014, 15:01
Does the disabled() method show an override symbol in netbeans? If not, you've spelled or capitalized it wrong (or something similar). If it does show an override symbol, then one possible explanation is that you are not downloading the program you think you are. Is your project set as the default project in netbeans?
As described in my previous post, the while loop and timer are both necessary. Please put them back in.
Unread 31-01-2014, 15:11
FRC #5202
I put them both back in and I am getting an override symbol in netbeans for all of the functions. It is also set as the main project in netbeans and there are no other programs written, so I don't know if it could possibly download a program that I don't know about.
Keep in mind that it may not be an issue with the program at all, it may be our motor controllers which are blinking yellow, as mentioned earlier.
Unread 31-01-2014, 15:14
Please post your current program (with the disabled() method) as well as the complete netbeans output. It may be helpful to zip your entire project and post it.
If it really is printing that you haven't provided a disabled() method, even though you have, the fact that the speed controllers aren't receiving signal is another symptom, not the root cause.
Unread 31-01-2014, 15:21
FRC #5202
Okay, that would make sense.
Here is the full code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.RobotDrive;
public class RobotTemplate extends SimpleRobot {
    RobotDrive chassis = new RobotDrive(1, 2);
    Joystick leftStick = new Joystick(1);
    Joystick rightStick = new Joystick(2);
     * This function is called once each time the robot enters autonomous mode.
    public void autonomous() {
      chassis.setSafetyEnabled(false);
      chassis.drive(-0.5, 0.0);
      Timer.delay(2.0);
      chassis.drive(0.0, 0.0);
     * This function is called once each time the robot enters operator control.
    public void operatorControl() {
        chassis.setSafetyEnabled(true);
        while(isOperatorControl() && isEnabled()){
            chassis.tankDrive(leftStick, rightStick);
            Timer.delay(0.01);
    public void disabled() { //a test to see if disabled() is ever reached
      Timer.delay(2.0);
    public void test() {
And here is the full console info:
ant -f "C:\\Users\\NRHS Skynet\\Desktop\\New Folder\\RobotTemplate" deploy run
clean:
Deleting directory C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build
Created dir: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build
Created dir: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\classes
[crio-compile] ./src, C:/Users/NRHS Skynet/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/NRHS Skynet/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/NRHS Skynet/sunspotfrcsdk\lib\squawk.jar -> ./build/classes
Compiling 1 source file to C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\classes
compile:
preverify:
Created dir: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\preverify
Created dir: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\preverify.raw.util
[crio-preverify] ./build/classes, , C:/Users/NRHS Skynet/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/NRHS Skynet/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/NRHS Skynet/sunspotfrcsdk\lib\squawk.jar -> ./build/preverify
Expanding: C:\Users\NRHS Skynet\sunspotfrcsdk\lib\wpilibj.jar into C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\preverify
Expanding: C:\Users\NRHS Skynet\sunspotfrcsdk\lib\networktables-crio.jar into C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\preverify
jar:
[crio-jar] ./build/preverify, ./resources -> ./build/app.jar
Building jar: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\app.jar
suite:
Created dir: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\suite
[crio-suite] ./build/app.jar -> ./build/suite/image
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
[Including resource: META-INF/maven/edu.wpi.first.wpilib.networktables.java/NetworkTablesAzalea/pom.properties]
[Including resource: META-INF/maven/edu.wpi.first.wpilib.networktables.java/NetworkTablesAzalea/pom.xml]
Romizer processed 388 classes and generated 4 files.
Expanding: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\app.jar into C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\suite
Moving 1 file to C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\build\suite
Deleting: C:\Users\NRHS Skynet\Desktop\New Folder\RobotTemplate\image.suite.api
deploy:
[crio-configure] Configuration files not included in this version of the sdk
[crio-configure] Checking that crio is configured for Java
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 24.45-b08
Target IP: 10.52.2.2
Network interfaces on host:
    Realtek PCIe GBE Family Controller:  address: 10.52.2.5 netmask: 255.255.255.0 <--- on robot's subnet
    Intel(R) Centrino(R) Advanced-N 6230:  address: 10.251.20.251 netmask: 255.255.255.254
Connecting FTP @10.52.2.2
[crio-deploy] ./build/suite/image.suite -> 10.52.2.2
Sending local file image.suite
run:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
   Waiting for cRIO to reboot (8s)
   Waiting for cRIO to reboot (9s)
   Waiting for cRIO to reboot (10s)
   Waiting for cRIO to reboot (11s)
[cRIO]
[cRIO] -> * Loading debug.o: debug
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO] Copyright 1984-2006  Wind River Systems, Inc.
[cRIO]
[cRIO]              CPU: cRIO-FRC II
[cRIO]     Runtime Name: VxWorks
[cRIO]  Runtime Version: 6.3
[cRIO]      BSP version: 1.0/0
[cRIO]          Created: May 23 2013, 16:00:09
[cRIO] ED&R Policy Mode: Deployed
[cRIO]    WDB Comm Type: WDB_COMM_END
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] * Loading nisysrpc.out: nisysrpc
[cRIO] * Loading NiRioRpc.out: NiRioRpc
[cRIO] task 0x18a70e8 (VISA Jungo Init Thread) deleted: errno=196709 (0x30065) status=-1073807360 (0xbfff0000)
[cRIO] * Loading nivissvc.out: nivissvc
[cRIO] * Loading nivision.out: nivision
[cRIO] task 0x1a15a40 (Service Locator Thread 5) deleted: errno=0 (0) status=0 (0)
[cRIO] NI-RIO Server 13.0 started successfully.
[cRIO] task 0x187f668 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1a1ede8 (Service Locator Thread 6) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1a1ede8 (Service Locator Thread 7) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1a1ede8 (Service Locator Thread 8) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1658320 (nisysapi-mDns) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading visa32.out: visa32
[cRIO] * Loading niserial.out: niserial
[cRIO] * Loading NiFpgaLv.out: NiFpgaLv
[cRIO] * Loading FRC_FPGA_ChipObject.out: FRC_FPGA_ChipObject
[cRIO] * Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication version: p4-1.4.0a18
[cRIO] FPGA Hardware GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C
[cRIO] FPGA Software GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C
[cRIO] FPGA Hardware Version: 2012
[cRIO] FPGA Software Version: 2012
[cRIO] FPGA Hardware Revision: 1.6.4
[cRIO] FPGA Software Revision: 1.6.4
[cRIO] * Loading FRC_JavaVM.out: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2012 FRC, Jan  5 2012, 17:20:48
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 13.0
[cRIO] task 0x18773c8 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Nov  5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] Default robotInit() method running, consider providing your own
Would you need the whole project in a .zip or just the .java code?
Unread 31-01-2014, 16:37
The whole project
Is this the directory that your project is in?
Unread 04-02-2014, 15:31
FRC #5202
The whole project
Yes the code is located in that filepath.
Unread 04-02-2014, 15:51
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by randantor View Post
Also, your netmask should be 255.0.0.0 though it may technically work if it's 255.255.255.0.
The tighter netmask 255.255.255.0 may help discern between the robot and the schools wifi setup and it definitely will work. But at competition it must open up to 255.0.0.0 to talk to the FMS.
Unread 04-02-2014, 16:23
FRC #5202
Alright our problem has been solved. We just created a new project and copy and pasted the old code into it. I guess the filepath of the old project was messed up.
