Re: Robot behaving strangely
In the LabVIEW project, do you have the target IP address set to 10.3.57.2, or is it 10.03.57.2? I've found that having a leading zero can confuse the networking sometimes.
Something else I forgot to add was that in the tele-op vi (where the drive code is), I gave a constant of zero to both sides and the side that moved without joystick command, moved. I moved the joystick axis and the other side did not move. I know that my coding is not wrong on the surface, but I don't know how in the world is this happening. Last edited by Kevin Phan : 31-01-2014 at 18:36. Reason: Additional information |
Tonight we created a new project and bit by bit reprogrammed the robot. I'm not sure what caused this phenomenon, but if it comes back...
