Go to Post Do you have to think about FIRST when you get up in the morning? - KenWittlief [more]
Thread Tools Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Unread 31-01-2014, 18:32
Maxchrist Maxchrist is offline
FRC #4458 (Infernobotix)
Maxchrist is an unknown quantity at this point
How do you Tune the PID Values?
Hi I am on a second year frc team from New York. We have been trying to program an autonomous program in java using motor encoders and a PID controller to move forward a specific distance. However, in order to uses the PID controller we need the proportionality, integral, and differential constants, and we do not know how to find them. We tried using the smart dashboard but nothing shows up in the window to edit. If someone could give us some help it would be greatly appreciated. Thanks!
Unread 31-01-2014, 21:08
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: How do you Tune the PID Values?
We are using Command based Java code and we are having trouble getting a PIDSubsystem to show up in the SmartDashboard LiveWindow when we put the robot in Test mode.
This link shows the PIDSubsystem showing up in LiveWindow and allowing you to edit all the PID controller values but we don't seem to be able to get this to work.
http://wpilib.screenstepslive.com/s/...manual-id=7932
For the original poster, when we put the robot into teleop mode and made the SmartDashboard editable we were able to right-click the PIDSubsystem and select PID editor. This looked like it would allow you to edit the PID constants at least. This was after using SmartDashboard.putData() to send the PIDSubsystem to the SmartDashboard.
Unread 03-02-2014, 13:22
vgdude999 vgdude999 is offline
Programmer/Driver
FRC #1751 (Comsewogue Warriors)
vgdude999 is an unknown quantity at this point
I was able to get the PID controller in livewindow using this line in the OI:
LiveWindow.addActuator("drivetrain", "Drivetrain", Robot.drivetrain.getPIDController());
EDIT: This is for test mode, I don't know about getting it in teleop.
2013: Rookie year, programmer-in-training; SBPLI Regional Finalists
2014: Co-Captain, Programmer, Driver; Seeded 15th
2015: Co-Captain, Programmer, Driver
Unread 03-02-2014, 14:05
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
For teleop, just do this:
SmartDashboard.putData("PID Controller",controller);
controller can be replaced by subsystem.getPIDController().
Also, in terms of actual tuning techniques, here's the procedure I use:
  • Raise the P constant until your controller oscillates. If the oscillations are too big, lower the constant a little bit.
  • Raise the D constant to damp the oscillation, causing it to converge. D also slows down the controller's approach to the setpoint, so striking a balance between P and D can take some tweaking.
  • If you have P and D tuned, and it oscillates & converges, but not to the correct setpoint, increase I. This is called "steady-state error" and a positive, non-zero integral constant will cause the controller to correct for it.
In general, P makes approach faster, but can cause larger oscillations; D causes oscillations to converge, but slows approach; and I can correct for steady-state error and causes faster approach, but can lead to intense oscillations if set too high (search "integral windup" for more details).
I code stuff.
