Go to Post The game objectives are still the same, get boxes into your scoring zone, stack approximately half of them, run for the top of the ramp. So lets sit down, shut up, and start building robots. - ChrisH [more]
Unread 31-01-2014, 20:27
AutoBotAM AutoBotAM is offline
AKA: Christian Reese
FRC #2077 (Laser Robotics (Laserbots))
AutoBotAM is an unknown quantity at this point
Parallel commands that depend on the same subsystem?
How would the two commands be ran in this situation? Either by running them in parallel in a command group, or if both commands were default commands of different subsystems.
I know that if one command is run that depends on a subsystem that another running command depends on, either of the commands are terminated depending on the circumstances. Is there a way to get two commands to literally run in parallel, accessing the same subsystem? So if commands A and B depend on subsystem C, the scheduler will execute A, then B, A, B, and so on.
Is there a way to get that working?
EDIT:
If there is not, I'll explain my design further. In this case command A would only read information from subsystem C. It would only use accessor methods and no mutator methods. So would it be safe to just omit the "requires" call?
"Mecanum drivetrains, like every other, have advantages and disadvantages, but some of the disadvantages being discussed here are overstated and/or misinformation." -buchanan
Unread 31-01-2014, 21:43
Re: Parallel commands that depend on the same subsystem?
Command A does not require exclusive access to Subsystem, so you should not use the requires call.
Unread 31-01-2014, 22:17
So there isn't a way to do the former. Otherwise answers my question, thanks!
Unread 01-02-2014, 00:33
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
If A and B both "require" C in your case, either you are trying to control the same physical parts of the robot (motor controllers, solenoids, etc) with 2 commands (bad and can have unexpected results), or your subsystem has 2 different (sets of) physical parts that the commands are controlling (in which case you should refactor said subsystem into 2 subsystems).
