Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Unread 31-01-2014, 19:29
Short Stuff's Avatar
Short Stuff Short Stuff is offline
AKA: Josh Noble
FRC #2594
Team Role: Human Player
Short Stuff is an unknown quantity at this point
Non-level bumpers
When our team builds our bumpers do the tops of all the bumpers have to be at the same (or at least very similar) heights? To be more specific: Do the front and back bumpers have to be at the same height as the side bumpers?
Unread 31-01-2014, 19:34
Re: Non-level bumpers
Please see Q199 and R22's blue box.
Longer answer: If a bumper section happened to be lower than the rest of the bumper sections, but the bumper was still level and entirely within the bumper zone, I can't see anything that would rule it illegal. However, if the bumper was angled, it would be illegal per R22 (blue box), clarified by Q199.
Unread 31-01-2014, 19:53
magnets's Avatar
magnets magnets is offline
The same blue box was present in 2013, yet angled bumpers were ok.
Unread 31-01-2014, 20:03
No blue box in the bumper section of the 2013 rules says anything about angle of bumpers. I checked the archived 2013 Manual just to be sure.
Unread 31-01-2014, 20:21
Jared's Avatar
Jared Jared is offline
See question 42 from the 2013 question and answer. It has the exact words from the blue box.
http://www.usfirst.org/sites/default...13_Q_and_A.pdf
If it was good to have angled bumpers with that answer, what rule makes it illegal this year?
Unread 31-01-2014, 21:47
As follows:
Q&A is not the rules. Correct? However, Q&A does interpret the rules, and give guidance on following them.
The difference between last year and this year is that this year, the ruling is in the rules, not the Q&A. Admittedly, it is in a blue box, AKA "intent and clarification", but it is still in the Manual.
Note too that the word "overtly" is used. Slight variations from level with the ground would probably be OK, you made the effort, but going from 10" (at the top) down to 7" (at the top) over the span of an 8" bumper would raise flags.
Unread 31-01-2014, 22:00
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I don't know how you're reading the "blue box". It specifically allows non-horizontal bumpers, as long as they stay in the 2"-10" range. Since the bumper is specified to be 5" high, that lets you slope it a massive 3". Even over an 8" run, I don't see that sloping it at atan(.375) =20 degrees is an "overt deviation", but then I'm not a judge. I think that they're trying to keep you from doing vertical pieces or something else silly, like putting a third row of pool noodle into that 3" of space.
That said, if you're design requires a bumper (or any other part) that you can't be sure fits the rules, change the design, or at least make a backup plan!
Unread 31-01-2014, 22:03
magnets's Avatar
As follows:
So, between 2013 and 2014, the definition of "overtly deviate" has changed.
This is horrible and extremely frustrating for me, as our team has designed our pickup off of an angled bumper. We figured that since this EXACT SENTENCE allowed angled bumpers in the past, it would again allow angled bumpers in the future.
Here's the rule which allowed them in 2013, and disallows them in 2014. If this can happen for this rule, who's to say that a all of a sudden roughtop tread is a traction material, and all roughtop wheels are illegal?
There is no explicit requirement that BUMPERS be perfectly parallel to the floor, however the
requirement that BUMPERS be constructed per Figure 4-4, the vertical cross-section, does implicitly
mean that a BUMPER should not overtly deviate from this orientation.
To begin with, this is just the GDC being lazy and copying a sentence from next year's manual and not giving an answer. This really doesn't answer the question at all.
The first part (there is no explicit requirement that BUMPERS be perfectly parallel to the floor) is fine. It means "nowhere does it say bumpers must be perfectly parallel to the floor".
The next part "however the
mean that a BUMPER should not overtly deviate from this orientation." A vertical cross section of an angled bumper would have the pool noodles be slightly oval shaped.
In 2013, an oval would not be considered "overtly deviated" from a circle, which makes sense, as a very slight oval could be mistaken, by everybody's favorite "reasonably astute observer" as a circle.
In 2014, an oval does "overtly deviate" from a circle.
If they're making changes like this, I'm begging for them to let us know before halfway through build season after we've wasted a lot of time and money building three sets of nice angled bumpers. But we'll be keeping our angled bumpers, because I'd be willing to bet that between now and the end of build, there's a chance that the definition of "overtly deviate" will change again.
In 2013, we made 4 competition bumpers (red/blue, angled/nonangled) and two practice bumpers (angled/nonangled) because of unclear rules
This year, we've made 3 angled ones, and again, because of THE SAME RULE, we're making 3 more. This sucks. Can the GDC get any more unclear?
Unread 31-01-2014, 22:05
magnets's Avatar
The answer to q268 says that angled bumpers are not legal by referencing the blue box, which states they are legal, but don't forget, the blue boxes aren't really the rules like the rest of the manual...
EDIT: that's q199, not 268. oops.
Unread 31-01-2014, 22:16
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
If you're complaining about a Q&A answer (to a somewhat vague question to begin with) not being sufficient enough, then ask a Q&A yourself with a more specific question (ie. can a single bumper segment be at a 45 degree angle with the ground or something).
And if the rule you quoted allowed angled bumpers last year, maybe, it technically didn't, but there was no one who asked a Q&A to get an interpretation of that rule. Maybe the GDC's intent of not allowing traction devices DOES include roughtop tread. If someone asked the Q&A if roughtop tread is a traction device, then we'd know for sure their stance on that.
What I'm trying to get at is, if you're committing to a design off an assumption of a sentence in a manual based off a past Q&A answer, you should probably ask it on Q&A for some form of further clarification
Unread 31-01-2014, 22:22
There is no explicit requirement that BUMPERS be perfectly parallel to the floor, however the requirement that BUMPERS be constructed per Figure 4?8, the vertical cross-section, does implicitly mean that a BUMPER should not overtly deviate from this orientation.
Emphasis mine. The blue box specifically states that the bumpers are IMPLICITLY required to be as close as possible to horizontal. Not explicitly required to be one way is not the same as specifically allowed to be another way. You're not explicitly required to use any particular fabric on your bumper, but a particular fabric is specifically allowed by implication.
Unread 31-01-2014, 22:25
Jared's Avatar
As follows:
I think it's still a gray area. In 2013, since there was nothing in the rules about angled bumpers, we showed our inspector at CMP the Q and A answer. He brought it to the LRI, who said that the rules permitted our bumpers (and the bumpers of 1114 and 67). This means that the current blue box (without any interpretation) permits bumpers, which the q and a contradicts. Normally, the rules from the manual would trump the q and a response, but the sentence in question is a blue box. So, which get used, the blue box, or a q and a (which references the blue box in question)?
Or, if magnets is right, and the meaning of the sentence has changed because they are now providing an interpretation of this sentence instead of just giving us a vague sentence, this means that the correct interpretation for this year (not legal) contradicts what they wanted teams to get out of it last year (angled bumpers are legal), which again, doesn't make too much sense.
I think they should address this in a team update.
Unread 31-01-2014, 22:26
magnets's Avatar
Then, the bumpers of 1114, 67, and 236 were illegal in 2013.
I assumed that the interpretation given by the robot inspectors at the CT regional, GTR east, GTR west, Waterloo, Galileo, and the michigan district was correct and that robots that competed in the final match of their division at CMP (in a configuration that they had throughout the whole season) were not illegal. If we say that this interpretation could have been wrong, then it opens a huge door to changes
Unread 31-01-2014, 22:29
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
And the answer posted on Q268 as I look at it now (several minutes after your post) says:
2014-01-31 by FRC5030
There is no published answer yet
Also, I read the question in 268 as probably referring to bumpers sloped so that the bottom of the bumper is not below the top of the bumper, since it is to " help aid the ball in rolling into our chassis". That is, sloped like snow plow or a cow catcher, not sloped so the bumper looks like a chevron when viewed from a distance.
Unread 31-01-2014, 22:32
magnets's Avatar
sorry that's q199. It explicitly disallows angled bumpers. No doubt about it.
