Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 31-01-2014, 22:51
ROBOGIRL2781 ROBOGIRL2781 is offline
FRC #2781
ROBOGIRL2781 is an unknown quantity at this point
NI9472 issue
Our NI9472 pneumatic card is reading 12 volts along all relay connections. We cannot get it to go down to zero in order to fire the piston. Any ideas as to why this is happening? Thanks.
Unread 01-02-2014, 00:08
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: NI9472 issue
Can you post a picture of how you have things connected/wired?
Also, have you read the pneumatics manual?
Unread 01-02-2014, 14:48
FRC #2781
Re: NI9472 issue
Never mind, we discovered the card had gone bad. Thank You anyways.
