Go to Post If this thread isn't a sign that CD is going through some serious withdrawals, I don't know what is. - Ty Tremblay [more]
Unread 31-01-2014, 23:00
ROBOGIRL2781 ROBOGIRL2781 is offline
FRC #2781
ROBOGIRL2781 is an unknown quantity at this point
Pneumatic Issue
Our NI9472 pneumatic card is reading 12 volts along all relay connections. We cannot get it to go down to zero in order to fire the piston. Any ideas as to why this is happening? Thanks.
Unread 31-01-2014, 23:49
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Pneumatic Issue
Can you post a picture of how you have things connected/wired?
Also, have you read the pneumatics manual?
Unread 01-02-2014, 21:51
Re: Pneumatic Issue
With the very tiny bit of information I can get from your description, I'm going out on a limb here and assuming something about your wiring. Do you perhaps have the solenoid wired with one side to battery and the other side to the output of the Solenoid Breakout? That'll always give you battery voltage on the output, because the NI 9472 is a Digital Sourcing Module. It can't pull a 12 volt signal to ground; all its outputs can do is either provide 12 volts or be essentially disconnected.
You're supposed to connect the solenoid between the two pins -- signal and ground -- of the channel on the Solenoid Breakout.
I apologize if I have assumed something which is not the case.
Unread 05-02-2014, 22:57
FRC #2781
Re: Pneumatic Issue
Thank you for your help. We figured out the card had gone bad.
