Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 01-02-2014, 00:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Help Identify This T-Shirt Cannon Robot Please
I look at this and I see maimed students.
PVC as a pressure vessel is very bad.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-02-2014, 01:22
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
PVC is what we use for our t-shirt cannon. We crank up our shoulder fired bazooka to 155PSI and blast shirts over our football stadium stands from the track. We have had the cannon since at least 2008 and have not overhauled it since it was built.
Unread 01-02-2014, 02:32
Cory's Avatar
AKA: Cory McBride
Just because it hasn't failed doesn't mean it isn't horribly unsafe.
2001-2004: Team 100
Unread 01-02-2014, 03:04
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Go with metal!
Unread 01-02-2014, 10:39
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
You can get a good sized metal air tank for cheap. The T-shirt shooter we built on 498 back in 2007 used a 5-gallon Campbell Hausfeld air tank from Walmart for under $50, and we just filled it with 2 kit-compressors in parallel. Didn't have to be replaced until a year or so ago, when they found some water starting to pool inside it. Since we didn't do any maintenance on it for 6 years I'd say that's a good life span on it.
The barrel on ours is PVC, but unless you jam it shut the odds of the barrel shattering before the t-shirt is dislodged are pretty low.
Unread 01-02-2014, 11:26
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
+1
This is extremely sound advice!
We stopped using PVC as our pressure chamber on our T-Shirt cannon because of the risk potential. We too have never had a failure, but the risk just didn't make it wise to use PVC.
We switched to ABS. It's cheap, easily available, easy to machine and has a failure mode that is safe. ABS will blister out, and then the blister "herniates". No explosion, no shards, no injury. Additionally, we have also never had a failure with ABS.
So, there really is no reason to use PVC when ABS will do the same job and not have the risk of injury.
Unread 01-02-2014, 13:33
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
I found this document from Charlotte Pipe, which is one of the leading pipe manufactures. Throughout the document, there are numerous warnings about using PVC/ABS/CPVC pipe in compressed air applications.
Originally Posted by Charlotte Pipe
Testing with or use of compressed air or gas in PVC / ABS
/ CPVC pipe or fittings can result in explosive failures and
cause severe injury or death.
• NEVER test with or transport/store
compressed air or gas in PVC / ABS / CPVC
pipe or fittings.
• NEVER test PVC / ABS / CPVC pipe or
fittings with compressed air or gas, or air
over water boosters.
• ONLY use PVC / ABS / CPVC pipe or
fittings for water or approved chemicals.
• Refer to warnings in PPFA User Bulletin
4-80 and ASTM D 1785.
On page 82, they specifically mention air cannons.
Do not use for SPUD GUNS, FLAMETHROWERS, or
COMPRESSED AIR GUNS. May result in property damage,
injury or death. Use only for fluid handling / plumbing
applications.
Everyone, please heed the manufacture's warnings. Only use materials meant for air pressure.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
