Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
  #46   Spotlight this post!
Unread 31-01-2014, 16:31
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: pic: Battery connector.....
The weight of a plastic connector is a drop in the bucket compared to the brick of lead, which varies by pounds between batteries of different manufacturers.
The big advantage is in current carrying capacity, which FIRST already limits using the 120a breaker. Most of the benefits are thermal, and prevent the wires from becoming sticky or melting (we frequently run the robot hard enough for the #6 wire on the battery to become sticky in 1 match time, at the very least it's always warm to the touch).
IMHO, the goal is usually to reduce weight for performance. If we ever are trying to add weight, it's always for CG management (esp. the 2012 bridge balance, or 2013 hanging).
I really want to put an end to the near-failures of the main power system we see every year. Even if the connectors don't fail catastrophically like the one in this picture very often, the wires are always sticky, and showing signs that they are undersized. And even if the connector is adequate, we can't easily put a larger wire in the connector, even if there are no rules prohibiting us from using a larger wire (currently we can use #4 wire for the battery side cable, so any argument of weight or capacity of the wire is null).
Kettering Motorsports
  #47   Spotlight this post!
Unread 31-01-2014, 16:45
I assume you are talking about the battery. If your battery weighs less than 12 to 13 pounds, you have vented a considerable amount of moisture to the atmosphere. There is a difference in the FR rated case but then again slight. Otherwise there is little difference in batteries.
  #48   Spotlight this post!
Unread 31-01-2014, 17:05
apalrd's Avatar
More Torque!
VRC #3333
We found that our gray batteries weighed on average 13 pounds, while the black-top ones weigh 14 pounds. I assume there is similar variance between manufacturers. OCCRA weights robots with the batteries, so we weigh all of them to find the lightest one to weigh in with.
The weight difference between the SB50 and SB120 plastic connectors is far less than a pound, so the weight difference isn't a significant advantage.
  #49   Spotlight this post!
Unread 31-01-2014, 18:19
http://www.chiefdelphi.com/media/photos/39426
Check out this from 2004, found my electrical students as we check through and unpack our boxes from our other build space.
Joe as promised...
  #50   Spotlight this post!
Unread 01-02-2014, 00:37
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
I did see that exact type of thing happen on our robot last year except not quite that far as they shut it off at the breaker. When the drive team came back from an early AM qualifying round, the student w/ the battery in his hands complained that I gave them a dead battery..."No way, no how" I said...as I checked it w/ a multi-meter myself I said just before handing it to him before the round.
I immed. began to inspect the battery Anderson clip Battery half (since it actually burned my hand during the semi-disgusted hand off) - and I saw melting of the clip & cables, and it was still very hot to the touch, so I took it apart and looked at the ends inside the clip...They were a bright orange copper color instead of alum. color.
I abruptly said...You do not have a battery problem folks..."You have a frame grounding problem," and pulled out the multi-meter from atop the battery cart and we began looking for the problem immediately. Sure enough, a frame grounding problem was immediately noted by a simple OHM check. That frame was grounded.
The hunt began....Sure enough, it took a while, but we found that (2 of the students had removed and reinstalled the CRIO the night before just before pit closing), and there was a nice short bright & shiny chromed Phillips Head screw near the bottom on the outside of the CRIO that was touching the lower chassis frame rail, that wasn't doing so the day before, (the CRIO's all come w/ that very unnecessary grounding screw), but, the CRIO is not supposed to be grounded to the frame in that manner at all. Same issue also cropped up w/ a grounded camera a few years back at champs that took a while to find.
Once that grounding issue to frame was cleared up...I have never seen that Anderson connector problem again. A simple ohm (00.00 meter read), check from battery to frame should tell you that you may just have the same exact problem I personally think.
I do know if they had not shut that robot power main breaker off very quickly, it could have been as bad as your pic or much, much worse. It did melt the outside insulation of the cables together right above the Anderson connector for about 2 inches (that was correctable as they pulled right apart and were still insulated properly, but those cable ends were junk), and melted slightly the connector itself...It was quite hot! That was very apparent.
Post back if you find it was a frame grounding issue please.
  #51   Spotlight this post!
Unread 01-02-2014, 00:54
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
I don't see how a Crio grounding issue could contribute that much to the failure of the main battery connector, the wires connecting it to the PDB would take serious damage if they passed that much current.
Also if a grounded frame was passing current, you have the even bigger issue of a positive line shorting to the frame as well.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
  #52   Spotlight this post!
Unread 01-02-2014, 01:26
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
The same amount of current leaves (red) the battery as enters (black). Either could have melted, the red just gave first
  #53   Spotlight this post!
Unread 01-02-2014, 01:43
Nirvash's Avatar
AKA: Bryan
FRC #4676
What I mean is, if your frame is 'grounded', it has the same potential of the negative terminal on the battery. No current should flow across it unless something with a positive potential is also shorted to the frame.
  #54   Spotlight this post!
Unread 01-02-2014, 01:52
FRC #0060
A simple check w/ a multi-meter will tell the tale. (But I know it happened, and our Ohmmeter did not lie...There was resistance present). Removed that screw, no resistance present. No more frame grounding issue
All I can tell you is; Removing the very unnecessary grounding screw on the blunt flat end of the CRIO cured up the frame ground issue immediately. The CRIO is powered by a regulated 24V power supply from the PD Board and am told by many since the incident (we have not before or since melted any of our Anderson connectors 2.5 minutes or hours), should never touch the frame (or ground to the chassis). That screw is chromed and unpainted. (And now completely gone from all of our Team CRIO's).
Go to this link; Scroll down to the Pic below "Attach To Robot" (where they instruct teams to attach your completed Control system boards to the robot).
http://wpilib.screenstepslive.com/s/...m#!prettyPhoto
Now, make that pic larger using the symbol lower right, look at the flat end of the CRIO in the left part of the pic. You will see the grounding screw I am talking about on the right hand side. (And that one is actually very close to that frame itself though not actually touching it in the pic, but could very easily later). Ours was caused by a hasty reinstall by 2 very tired students is all.
http://wpilib.screenstepslive.com/s/...dware-overview
"The PD provides a regulated 24V power supply to power the cRIO, a special, regulated 12V power supply for powering the robot radio and a 5V power supply for powering an Axis camera."
Are you absolutely sure it could not possibly have caused that? We know why that screw grounded to frame, and we know it cured up our issue, that bot still sits in our shop and still runs today. And did the rest of that day.
  #55   Spotlight this post!
Unread 01-02-2014, 02:10
FRC #0060
Nirvash,
Ever taken a No Good CRIO apart that has been used on a competition bot before? One that has been drilled on for a season or 2, etc.....Alum. flakes are everywhere on the surface of the board. I didn't actually check that screw to see if there was any positive current present w/ the battery connected...The battery was already out and in hand when we received the bot back at the pit.
I was only saying check it first. Thousands of hours of runtime, and only a few failures, points away from the Anderson Connectors in my mind is all.
The most costly failures I have seen so far have been caused by a wayward staple (from the back of a bumper), down in a sidecar crossing about 10 pins, and some magic smoking motors turned to actual flame. But 2 major items that will frame ground are that CRIO and the rear grounding lug if used for mounting on the older cameras. Though Jags & CAN I am not at all happy with since it cost us big 2 years ago repeatedly.
I'd bet Texas Instruments could tell us why that screw is even there.
  #56   Spotlight this post!
Unread 01-02-2014, 03:10
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Of course, I know this. I was merely positing the reason for rejection by the GDC. Whether the reason for the ruling is weight, current or dyspepsia is all a matter of conjecture anyway. Making your case(s) for a larger connector here may be considered preaching to the choir but keep it up now that we have been assured that there is some notice of CD being taken by the GDC. I'm not sure when the transition to happens but as long as Al is talking, I'm listening.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #57   Spotlight this post!
Unread 01-02-2014, 07:56
In the event of a frame fault, the cRio and/or DSC can produce some really crazy issues. In this case I suspect that the fault may have caused multiple motors to turn on in opposite directions or were commanding movement when none was possible. Why? High current in the #6 wire has to go someplace. If it shorted in a #18, then the breaker trips and the wire goes poof. If multiple loads are drawing extreme currents, then no breakers trip and no other wire gets hot enough to melt. When robots get crazy, suspect a frame fault first and look for it. It is sometimes difficult to find. You can try by pulling breakers and adding them back one at a time while looking for the issue. This is how the Banebot shorts were found a few years ago.
  #58   Spotlight this post!
Unread 01-02-2014, 08:05
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
I'm going with one or more of the following possibilities. Loose connection causing resistance, a failing crimp causing resistance, corrosion on the terminal causing resistance, or possibly a loose fit between the terminals when plugged together causing resistance.
  #59   Spotlight this post!
Unread 01-02-2014, 08:10
Michael Hill's Avatar
Agreed. Just because your chassis is grounded doesn't mean you're going to have battery melting problems. Heck, the chassis of most cars and airplanes are grounded and those batteries don't melt....well not usually (I'm looking at you lithium-ion...)
  #60   Spotlight this post!
Unread 01-02-2014, 09:11
apalrd's Avatar
More Torque!
VRC #3333
I do not know if there were grounding issues with either robot, but neither robot acted erratically at any time (one of them was competing in an off-season).
We know that one of them was drawing significant drivetrain current because the frame re-bent. Our 2011 robot crate was dropped while loading on it's way to the championship and the frame bent, but we hammered it straight at CMP. It re-bent at the Kettering Kickoff off-season, and melted 2 battery connectors in the same day. The replacement connector was taken from a battery as we did not have spares (they had never failed before).
The other robot was a practice robot. We geared it a bit too high, and practiced with it very hard. Eventually we added large KOP fans (the metal kind that were in the kit for a few years) to the drive motors to help them cool down (the CIM motor wires were getting very hot). The front roller was also very lossy so we threw more motors at it to get it to a reasonable speed (we had a 'joe johnson style' cross feed roller using bevel gears). The robot in general was a power hog without any additional issues. The main breaker should have tripped if we were using too much current, it did not.
During the 2012 comp season, we tripped the main breaker 3 times, then started cooling the main breaker using a cold bag of washers (set in a cooler of dry ice between matches), and replaced the battery cable to prevent failures at MSC.
The point is there are robot use cases that can melt the battery connector BEFORE the main breaker trips. This is a SAFETY ISSUE. Even if we are drawing too much current, the whole point of the main breaker is to open before any major safety issues happen.
