Go to Post Maybe it's the guy who doesn't stop drawing in his notebook in class, or the girl who writes the best essays in English. What team can't use their skills? - KathieK [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 09-09-2013, 13:56
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Talon SR issues
Hello! We just got our chassis assembled and running Mecanum drive code, and we've hit an impasse. Actually two of them. First, the talons all receive a signal and 'twitch' when they are not supposed to be receiving a signal and more so when at least one of them is. It causes the robot to 'creep' when enabled but not being controlled. We are going to try to calibrate them with our controller today, but it happens when no controller is plugged in, so it's a bit unnerving. It doesn't severely mess with driving, though. The other problem will hopefully be fixed with calibration. The motors spin about 50% faster in reverse than they do while going forward (meaning that the robot will arc while strafing and strafe a little while driving). Does anyone know if these are things that should/can be adjusted within the program or if these are caused by bad Talons (probably not)/sidecar/PWM cables? Do other people have this issue? Thanks!
Unread 09-09-2013, 14:08
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Talon SR issues
Make sure you're using the right Talon objects in code, as RobotDrive will create Jaguars by default. Posting language info/code could be helpful.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 09-09-2013, 17:08
ekapalka's Avatar
FRC #3216
Re: Talon SR issues
Thanks for your reply :) My code is located on this thread (I decided to ask on the current thread because I was hoping It would be read by more electrical-oriented people). I know the motors are initialized in the wrong order, but that shouldn't cause the problem, right?
Unread 10-09-2013, 01:54
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Talon SR issues
We had a problem with motors twitching last season and yes they were controlled by Talons, however the problem turned out to be a fried component in the DSC. My not be your problem but if you have another DSC it is worth a try to swap it in.
Unread 10-09-2013, 14:02
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: Talon SR issues
I never got to use the Talon SR, but your problem sounds like a faulty wiring problem, check for shorts (both in the power cords and information cords [=PWM]), make sure your PWMs are all in the correct places and aren't flipped over (it shouldn't cause your problem but won't hurt to check anyway), make sure there aren't any jumpers next to your PWMs in the DSC.
Also, I know very little about programming so I can't explain this, but in 2012 our robot moved without command once when it was enabled, and our programmer said something about dividing in 0. Dunno where or why it made that happen.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 01-02-2014, 13:37
wildbot3844 wildbot3844 is offline
AKA: James Helton
FRC #3844 (Kentucky Wildbots)
wildbot3844 is an unknown quantity at this point
Re: Talon SR issues
Can you post what the code should look like to control a drive with talons?
Unread 01-02-2014, 15:25
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Talon SR issues
By drive I assume you mean a robot drivetrain? That depends on what language you are using. Here's a quick example in Java:
import edu.wpi.first.wpilibj.*;
 * Simple example of how to use Talons to control a drivetrain
public class TalonExample extends IterativeRobot {
    private Joystick joystick = new Joystick(1);
    private Talon leftMotor = new Talon(1);
    private Talon rightMotor = new Talon(2);
    // Pass the RobotDrive constructor the two Talon objects we created
    private RobotDrive drive = new RobotDrive(leftMotor, rightMotor);
    public void teleopPeriodic() {
        drive.arcadeDrive(joystick.getY(), joystick.getX());
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
