Go to Post The teams that do the right thing for the sake of doing the right thing, and for believing in the message of FIRST deserve to be recognized. - Madison [more]
Unread 01-02-2014, 13:58
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Jaguar Questions
There is no out-of-box initialization that must be done for a PWM-controlled Jaguar. There is configuration for using them with CAN.
Back to the beginning now though, are you saying when you wire it to the PDB that the LED on the Jag does not light up at all? check your PDB (just for my sanity) make sure there is no red LED light showing on the PDB saying that either A) your breaker is tripped, or B) there is no fuse installed on the PDB power ports you plugged your Jag into.
If the above don't solve your problem you are the proud owner of a broken Jaguar motor controller and you should contact VEX customer support.
John Fogarty
