Go to Post In my opinion, the right mix of student, mentor, and engineer involvement is when everyone gives it 100%. - Jack Jones [more]
Unread 01-02-2014, 16:05
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: issues with Solenoid(Valve)
Originally Posted by team1631 View Post
Last week we had a perfect setup for our bot. Everything worked fine. We could shoot the ball and the such. Our president made the decision to up our valve from a 12v to a 24v. We did it, and suddenly it didnt work. We set it up all right, we put it through the 24v on the power board and all. But it just wouldnt work. Finally after a day or two we decided to go back to our 12v, and found that it wouldnt work as well. We have NO clue as to why. All of us have little experience with this issue and with pneumatics in general. The solenoids are receiving power but the valve isnt turning on or off.
Is the system pressurized while you are testing the valves? The valves we use generally have a minimum PSI needed to switch, this includes the outputs of valve. If an output is venting to the room, the valve will not switch.
Also, how did you verify that the valve was receiving power?
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 01-02-2014, 16:22
team1631's Avatar
team1631 team1631 is offline
FRC #1631 (Rockin Robots)
team1631 is an unknown quantity at this point
We used a voltage meter to check if it was receiving anything. Pressurizing is kinda hard to do when the valve starts open.
Unread 01-02-2014, 16:25
Nirvash's Avatar
AKA: Bryan
FRC #4676
That would be your issue, the valve outputs can not be open to room air. Connect a short length of tubing to the outputs and kink it(And probably ziptie it to hold it in place), then try.
Unread 01-02-2014, 16:35
team1631's Avatar
Thanks we are trying that out now. I'm just to clarify you said that the output venting to the room needs to be kinked so that we can switch the output that starts off?
Unread 01-02-2014, 16:40
Nirvash's Avatar
AKA: Bryan
FRC #4676
Just to make sure everything is clear, I assume you are using double acting valves, which have 3 ports on one side and 2 on the other.
Like this:
Output1 Output2
Vent1 Input Vent2
The input is the obviously connects to the pressure system.
The vents have nothing connected to them.
Both outputs must be able to pressurize, a simple way to do this is to have two kinked lines on the outputs.
Unread 02-02-2014, 00:14
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The kinked lines are there merely as testing for solenoid activation in the absence of an actual cylinder. Once you confirm the solenoid operation, you can remove the kinked line and eventually hitch the unkinked tubes to the cylinder(s). BTW we use a tubing T-fitting with one "input" tube and another tube that goes from one leg to the other of the T. This is effective as a stop wherever you need to plug a tube run for leak checking, etc..
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
