Thread Tools |
Rating:
Display Modes |
Re: Robot in 3 Days: Team O-RYON
We didn't break it with a load. I believe what caused it to break was the mouth we had as a "hard stop." We didn't have an actual hard stop so we just went full speed until you hit the lip and I think the repeated hits eventually broke it. We also realized that one gearbox was 25:1 and the other was ?20:1? I believe and the different torques caused it break as well. We just recently replaced the gearbox so we should have to correct ratios on both sides without any issues.
I know this is nearly 2 months old but I was wondering how you coded the launcher to be consistent every time. I have looked at the code that was posted and I cant seem to find any sensor or even a time constant to control the movement. Was it that you guys just had it set to run whenever the joystick button was pressed?
You definitely want to use sensors to control the motor launcher. Look at Boom Done's motor catapult for tips on what type of sensors you can use. |
We would love your help! Thanks!
