Go to Post Remember, the song is FIRST and the competition. We are the group. We dance to FIRST, we move because of it. - Joe Matt [more]
Unread 01-02-2014, 15:37
team1631's Avatar
team1631 team1631 is offline
FRC #1631 (Rockin Robots)
team1631 is an unknown quantity at this point
issues with Solenoid(Valve)
Last week we had a perfect setup for our bot. Everything worked fine. We could shoot the ball and the such. Our president made the decision to up our valve from a 12v to a 24v. We did it, and suddenly it didnt work. We set it up all right, we put it through the 24v on the power board and all. But it just wouldnt work. Finally after a day or two we decided to go back to our 12v, and found that it wouldnt work as well. We have NO clue as to why. All of us have little experience with this issue and with pneumatics in general. The solenoids are receiving power but the valve isnt turning on or off.
Unread 01-02-2014, 16:05
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: issues with Solenoid(Valve)
Is the system pressurized while you are testing the valves? The valves we use generally have a minimum PSI needed to switch, this includes the outputs of valve. If an output is venting to the room, the valve will not switch.
Also, how did you verify that the valve was receiving power?
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 01-02-2014, 16:22
team1631's Avatar
We used a voltage meter to check if it was receiving anything. Pressurizing is kinda hard to do when the valve starts open.
Unread 01-02-2014, 16:25
Nirvash's Avatar
AKA: Bryan
FRC #4676
That would be your issue, the valve outputs can not be open to room air. Connect a short length of tubing to the outputs and kink it(And probably ziptie it to hold it in place), then try.
Unread 01-02-2014, 16:35
team1631's Avatar
Thanks we are trying that out now. I'm just to clarify you said that the output venting to the room needs to be kinked so that we can switch the output that starts off?
Unread 01-02-2014, 16:40
Nirvash's Avatar
AKA: Bryan
FRC #4676
Just to make sure everything is clear, I assume you are using double acting valves, which have 3 ports on one side and 2 on the other.
Like this:
Output1 Output2
Vent1 Input Vent2
The input is the obviously connects to the pressure system.
The vents have nothing connected to them.
Both outputs must be able to pressurize, a simple way to do this is to have two kinked lines on the outputs.
Unread 02-02-2014, 00:14
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The kinked lines are there merely as testing for solenoid activation in the absence of an actual cylinder. Once you confirm the solenoid operation, you can remove the kinked line and eventually hitch the unkinked tubes to the cylinder(s). BTW we use a tubing T-fitting with one "input" tube and another tube that goes from one leg to the other of the T. This is effective as a stop wherever you need to plug a tube run for leak checking, etc..
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 03-02-2014, 12:14
Electrical things rarely like switching voltages arbitrarily. Next time someone asks you to change things that are working, it might be worth asking why.
Unread 06-02-2014, 23:18
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
I'm confused about kinking the outputs. Are we talking about Festo valves?
I've had 3 of these open and completely disassembled to clean them (There was some moisture inside for some reason, probably kids blowing in them). The small electric solenoids on each end open to pass air to transfer the pneumatic valve. I wouldn't see a reason the outlet needs to be kinked.
Furthermore when I finished cleaning the 3 of them I had, and reassembling them, all 3 operated and transferred back and forth with the outputs open to air.
As far as testing them without air first, electrically, you should hear the electric solenoid transfer. (a small click)
Unread 06-02-2014, 23:52
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
There is no need to "kink" the output hoses for the valve to switch, but there is a need for a minimum amount of pressure to be available on the input side for the valve to fully switch as many of the valves used in FRC are air piloted. So if you hook it directly to a compressor and try to make it switch the loss of air out of the side that is currently activated may be large enough so that pressure doesn't build high enough for the valve to switch.
