Go to Post But sometimes you just wanna build something that's MFD. - Andrew Schreiber [more]
Unread 01-02-2014, 17:46
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Drive is inverted!
This year we are using 4 talons to drive our robot. We have two of them hooked up per pwm using andymarks slpiced pwm cable. So in the robotdrive code we have two talons, the left and the right. We are using an xbox controller for tank drive but when we drive, everything is inverted. The motors are hooked up right but front on the xbox is back, back is forward, left is right and right is left. Can this be fixed in our code?
Unread 01-02-2014, 19:21
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
Re: Drive is inverted!
Instead of:
drive.tankDrive(joystick1.getRawAxis(2), joystick1.getRawAxis(5));
Try:
drive.tankDrive(-joystick1.getRawAxis(2), -joystick1.getRawAxis(5)); //Xbox
Putting a negative sign in front of joystick it will invert and now it should work fine.
Unread 01-02-2014, 19:57
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Ok ill try that tomorrow morning whenever i can stop by my school
