Go to Post Make sure you THOROUGHLY understand the rules of the game before you actually start designing the robot. - Koko Ed [more]
Unread 01-02-2014, 19:58
josmee443 josmee443 is offline
AKA: Jonathan Ma
FRC #1758 (Technomancers)
josmee443 is an unknown quantity at this point
Locking Mechanism for Catapult?
Hi Guys!
My team (Team 1758) has been working on a locking mechanism for our catapult in the past couple of weeks, but we can't seem to come up with a smoothly working design. Our most recent idea was using the locking mechanism of a doorknob. The latch of the doorknob holds down the catapult and a piston pulls back the patch to unlock the catapult. However, due to friction, this mechanism does not work all of the time (maybe 50% of the time). Do you guys have an suggestions for a good working lock mechanism for a catapult system?
Thanks!
Unread 01-02-2014, 20:02
Re: Locking Mechanism for Catapult?
Originally Posted by josmee443 View Post
Hi Guys!
Gate latch. Ball shifter with gear removed. Pin through an eye bolt with a teflon insert. Pawl. Over-center lever. Door-lock electromagnet (are those legal this year)?
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Our team is using a gate latch. It's very simple, strong, easy to use, and easy to release.
Unread 01-02-2014, 20:13
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Doorknob.
Unread 01-02-2014, 21:38
Originally Posted by apples000 View Post
Doorknob.
Any particular model? The OP said they were using a dooknob and it wasn't working for them:
...The latch of the doorknob holds down the catapult and a piston pulls back the patch to unlock the catapult. However, due to friction, this mechanism does not work all of the time (maybe 50% of the time).
Unread 01-02-2014, 21:41
David Fort David Fort is offline
FRC #1001
David Fort is on a distinguished road
Pneumatically actuated hatchet that cuts the rope.
(worked back in the day just fine).
I suppose that has the disadvantage of only working once.
Our team is partial to rope clutches (from sailboat). It can take a lot of force to release, but if you are more clever than we are, it can probably be mitigated.
I like systems that are "balanced" and the force to release them does not fight against the holding force. For example, a rope wrapped around a post. It holds if the tension is perpendicular to the post, but if you rotate the post down, the rope slides off the top.
Unread 01-02-2014, 22:49
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
2008 Chevrolet Impala truck latch. Should be available at any Chevrolet dealership.
A little awkward to package/mount, but will hold a lot of load and can be easily released with a servo.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 01-02-2014, 23:45
AKA: Jonathan Ma
Could you possibly describe how your team's gate latch works?
Unread 01-02-2014, 23:49
AKA: Jonathan Ma
How would those work?
Unread 01-02-2014, 23:56
rwkling1's Avatar
Sure! So our team purchased a gate latch similar to this:
http://www.menards.com/main/tools-ha...218-c-9694.htm
And what we have, is we attach the "peg" or whatever you want to call the piece that goes into the actual latch is mounted to our shooter. We attached a pneumatic cylinder onto the actual latch, so that when the cylinder is extended, the latch is closed, and once we retract it, it pulls back the latch, releasing the shooter. We also have a limit switch making sure that we don't winch the shooter down to much.
Unread 02-02-2014, 00:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Was that what you used for your famous Einstein winning hang?
-Plutarch
Unread 02-02-2014, 00:59
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Hey we tested with this exact same thing! It worked really well but we ended up going with a different shooter instead, however I would recommend it for you guys!
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 02-02-2014, 01:12
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
In 2010 we used a gate latch to hold and release out kicker. You can see it in this photo before the kicker was installed in the robot.
It was activate with a 1 inch throw cylinder, as seen here.
Unread 02-02-2014, 07:53
Gdeaver Gdeaver is online now
FRC #1640
I've used a pneumatic coupler and a cylinder to pull the collar back. A ball lock device.
Unread 02-02-2014, 08:36
Storcky's Avatar
Storcky Storcky is offline
FRC #3634 (Hard Botties)
Storcky is on a distinguished road
In 2008, we just used a piston to lock. You can see it up close in the beginning of this video. http://youtu.be/JKdTJSR-KuU
Alum of 1629 - GaCo [2005-2008]
Mentor for 3634 - Hard Botties [2013-2015]
Mentor for 230 - Gaelhawks [2013-2015]
Pittsburgh Regional Planning Committee [2016-?]
