Re: [URGENT]"no robot code" on the driver station??[URGENT]
This is the third time you have posted this. It's really hard for anybody to help you, as this could be caused by a large number of things. Try loading a new default robot project on the robot.
If I recall correctly, when ever we fully deploy code onto our robot, we have to restart it before the driver station indicates that code is on the robot. We are using labview.
When you download the code and reboot the cRIO, open up netconsole and look at the output when the cRIO boots up. If there is an error within the code the code will not run, so check the output which will show what the error is. This is what I do whenever it happens to me, and I use C++ as my programming language. It may or may not work for you, but you can try. I'm not sure if netconsole works with the other programming languages.
A clarification for all of you that are kind enough to help. We programmed in C++. Sadly I have next to no knowledge in programming so there isn't much else I can tell you. All I know is when we use a basic code that we wrote to see if the code was being properly uploaded, everything was good on the Driver Station. We were also able to do the same once adding basic drivetrain code to (coded 6 talons). However our issue came up when we attempted to add pneumatics onto the code. Whenever we tried to activate the compressor there was no signal on sidecar. The solenoids were getting signal though! Again I would like to sincerely apologize for the minor post spamming, I hope that you guys are able to help. Thanks, Kevin |
Re: URGENT: Code not working for various reasons
3 threads merged into 1
When deploying code from WindRiver, have you gone into Window->Preferences->FIRST Downloader Preferences and made sure the right file is selected? Simply creating a new project or building a different one doesn't change this setting. Also make sure that the project was built -- just deploying code doesn't automatically rebuild for you.
#7
The original problem posted by the OP re: no code was figured out (though Reed may not be fully aware as he was offline today). The problem is as discussed here where code errors/issues are not surfaced when compiling or linking or deploying. They are only surfaced in Netconsole after you deploy and then restart crio (when using WindRiver c++, not sure about elsewhere). So, if you are not paying attention to Netconsole you could be led to believe that you have deployed code, but you haven't. The code seems to get FTPd to crio, but not implemented on crio restart.
This being a "single-mode OS" seems to be the underlying force behind this happening. At least in some cases. If you run into this kind of problem (where you successfully deploy code, but DriverStation continues to say no robot code) then check Netconsole for hints as to why. Regards |
#8
Unfortunately my previous post was not entirely correct. Although that was a problem we encountered it was not actually the first problem related to the symptom first reported by the OP. The initial problem was that clicking "deploy" resulted in nothing happening. The code was not getting sent to crio. This problem still happens. Although we have messed about and can sometimes circumvent the problem we have not yet figured exactly why it happens.
When we click deploy, the deploy window appears very, very briefly. This is clearly different than when we have a successful deployment where the window appears and shows the progress bar during the activity. Netconsole shows nothing during this time (though I don't know if it is supposed to show anything). |
#9
HTH |
#10
I noted in the list of posts here that the cRio may not have been updated to this years image yet? Is that correct?
We had issues with is running by on the format and update image that it had the rebooting crio and did not take any time on the other steps. I know we had struggles with it and had to do the following. Make sure all network interfaces were disabled, then only use the wired net connection and plug into the bridge/AP. Make sure the firewall is off. Make sure you can ping the cRio. open the imaging tool. See that the cRio is found. On the 8 slot crio change the switch to safe mode On the 4 slot do it on the imaging tool. Make a minor update (change name, change language, add the can) for instance, do not choose format cRio. Safe mode will prompt to image cRio. Say yes. This should take a little while and not jump right to rebooting crio message. After it is done turn off the safe mode switch and then in the imaging tool choose to format the cRio with the new image. Then the code will need to be deployed. This was the only way we were able to get both cRio's we have to the current software revision. If you are still having issues with the C++ code deploy then maybe try jumping over to a labview of java code set and see if that will work for something as simple as reading the joystick value. If you can get that to work, then maybe something is incorrect in the WindRiver setup. Hope this may help. Randy |
#11
So how does one make sure their code will load and run (2 distinctly different issues)? Most FIRST programmers simply deploy and debug using print/log/smartconsole output. But without using the debugging interface to the robot, you will miss messages about the unresolved symbols and/or tasks getting suspended for various violations (memory access, divide by zero etc). Instead create a target server and load and run your code using the debugging tools and you will see these errors and fix them. FIRST has a tutorial that covers this procedure. NetConsole MIGHT catch them depending on how badly the errors cripple the OS on the robot. http://wpilib.screenstepslive.com/s/...-robot-program Many of you might think this is a lame setup. But I remind you this exactly how adding code to the Linux kernel (and many other operating systems) works. WindRiver and VxWorks are not unusual in this respect. HTH Last edited by wireties : 03-02-2014 at 14:58. Reason: added link to debugging tutorial |
