Go to Post Injuries can come out of no where. I know this is only a robotics competition but the injury doesnt care where or what you are doing. - nightrenegade00 [more]
Unread 01-02-2014, 11:30
RedLight RedLight is offline
RedLight is an unknown quantity at this point
Encoder Trouble
We use Java and have Grayhill 63R encoders that do not work. We have checked the wiring and it is fine. The a and b signals are taking up 2 different channels, it has power and ground, and the wires are not broken. The constructor is :
driveLeftEncoder = new Encoder(3, 4, false, EncodingType.k4X);
We also remembered to start and reset it. When printing the values, the encoder always returns 0 for the get() method, .25 for the getDistance() method, 1 for getRaw(),and true or false at random for getDirection(). Unless we stop then start it, the rate is 0, and when we do it is a random value. Also without stopping and starting it, it always returns true for getStopped(). We are utterly confused as to what is wrong and would appreciate any help.
Unread 01-02-2014, 11:33
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: Encoder Trouble
An issue that can easily get over looked is do you have your encoder reset inside a while function? And would you also mind posting your code?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 01-02-2014, 11:54
sarangmittal's Avatar
sarangmittal sarangmittal is offline
FRC #1683 (Techno Titans)
sarangmittal is an unknown quantity at this point
Re: Encoder Trouble
Another thing crucial to getting Encoders to work is using the setDistancePerPulse() method.
You experimentally determine this constant by rolling the robot over a pre-determined distance, and recording the number of pulses from the get() method.
Then it's as easy as dividing distance by the number of pulses, and using the setDistancePerPulse() before getting the distance.
Hope this helps.
If this still doesn't work, maybe try posting the code, and we can look it over.
Unread 01-02-2014, 18:36
Michael U Michael U is offline
Programmer
FRC #2980
Michael U is an unknown quantity at this point
Unhappy Encoder Trouble
For the past two weeks our team has tried to get our US Digital encoder working. We cannot read any values from the encoder at all. Our wiring is the same as this:
And our code is attached.
We have tried to test everything that we could think of. Please help us find what is wrong so we can get them working. Thank you very much for your help, we really appreciate it.
Unread 01-02-2014, 18:49
Re: Encoder Trouble
Are you really connecting the encoders to the DCS PWM outputs rather than the DIO?
Unread 01-02-2014, 18:57
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Encoder Trouble
Maybe he meant PWM cable
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 01-02-2014, 18:58
Re: Encoder Trouble
I hope so. But that needs to be confirmed.
Unread 01-02-2014, 19:19
Programmer
FRC #2980
Re: Encoder Trouble
Sorry for the confusion, we are connecting them via pwm cable to the "DIGITAL I/O" on the digital sidecar.
Unread 01-02-2014, 19:58
Re: Encoder Trouble
Does your team have access to an oscilloscope, even a cheap one?
Unread 01-02-2014, 20:09
Programmer
FRC #2980
Re: Encoder Trouble
Yes, we do own an oscilloscope.
Unread 01-02-2014, 20:14
Re: Encoder Trouble
Look at the output of the encoder(s). See if there's any signal coming out.
You may have to carefully strip the insulation of a small section of the signal wires.
Unread 01-02-2014, 20:25
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Encoder Trouble
]You may have to carefully strip the insulation of a small section of the signal wires.
I was taught by an smart EE to use a scribe to poke through the insulation of the wire, then touch the probe to the scribe. Super easy, and the wire isn't exposed when you're done (you should still warp it in electrical tape afterward)
The same guy taught me to strip wire using small side cutters, another handy trick.
Kettering Motorsports
Unread 01-02-2014, 21:02
Programmer
FRC #2980
Re: Encoder Trouble
We are getting signals from channel a and channel b. (it looks like a pwm signal)
Unread 01-02-2014, 21:31
Re: Encoder Trouble
Of course. Thank you. I suppose you could use a needle or a pin in a pinch.
Unread 01-02-2014, 21:33
Re: Encoder Trouble
A and B should be in quadrature. Are they?
