Go to Post the truth is that a 'bot is only as complicated as you make it. - RogerR [more]
Unread 01-02-2014, 07:09
Twitchy's Avatar
Twitchy Twitchy is offline
Robot Addict
AKA: Mark Peterson
FRC #2826 (Wave Robotics)
Twitchy is an unknown quantity at this point
pic: Practice Field Teaser
Team 2826 is almost done with our practice field construction.
Name:	Practice Field.jpg
Unread 01-02-2014, 07:49
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: pic: Practice Field Teaser
Color me green with envy. Nice work!
Jim
Unread 01-02-2014, 08:58
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
The perks of having a not-classroom to work in. If only!
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 01-02-2014, 10:40
toramo toramo is offline
FRC #0612
toramo is an unknown quantity at this point
Looks great! Well done.
Just yesterday we got a local landlord to donate this space in Northern Virginia through April:
http://360.io/4969Mz
We are setting up our practice field next weekend along the same lines as you guys. Any advice would be greatly appreciated, especially if you happened to have plans or a BOM (beyond what FIRST provides).
How long did it take you to get this far? About how much did you spend on wood?
Also, we want to simulate the plexiglass on the driver's station but actual plexiglass seems prohibitively expensive. What are your plans there?
This is the first time we've attempted to build a practice field since we operate out of a school, but this year's field seemed simple enough to give it a shot. We're also building two bots for the first time so this will help motivate the team.
Unread 01-02-2014, 22:11
You don't want Plexiglass anyway -- it's not hard to shatter it with a sharp impact. The material used for the Alliance Station "glass" is polycarbonate (e.g. Lexan), not acrylic. It's used as bulletproof glass.
Polycarbonate is even more expensive than acrylic, so you probably don't want it ether. Our old practice field ten years ago used something I think is called hardware cloth. It was a metal mesh with wide square openings, on the order of 3/4". I don't recall whether it was welded at the intersections or not.
Unread 02-02-2014, 20:08
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
Mark,
Does the green reflection interfere with your vision recognition?
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 05-02-2014, 15:00
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Team 2826: Are you going to open it up for other teams to practice? Are you holding a Week Zero Scrimmage? If you are, please post the details in this thread as well: http://www.chiefdelphi.com/forums/sh...d.php?t=125139
Nice looking field, by the way!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 05-02-2014, 15:10
It looks like you have a bunch of equipment in the background. Do you have machining capabilities on site? Looks like a great work space.
Unread 05-02-2014, 15:16
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Wow.... I wish we had the space for a full field this year. Nice job guys, and see you at the competition.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 05-02-2014, 15:18
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
Originally Posted by Mark Holschuh View Post
Mark,
We haven't had any issues with vision as far as I am aware. I think the green you see in the photo is just from the camera Mark used.
Yes we have a mini lathe, and a router table as well as a smattering of other typical small shop tools/machines.
2012-2016 Wave Robotics Team 2826
Unread 07-02-2014, 04:30
Twitchy's Avatar
Robot Addict
AKA: Mark Peterson
If you would still like a BOM, and some potential assembly drawings to help you build your field I can try to put something together today. Just let me know where you would like me to send those to.
Unread 07-02-2014, 04:35
Twitchy's Avatar
Robot Addict
AKA: Mark Peterson
We got our truss up this past weekend.
Name:	Practice Field #2.jpg
Unread 07-02-2014, 04:39
Twitchy's Avatar
Robot Addict
AKA: Mark Peterson
We got our driver stations completed last night.
Name:	Driver Stations #2.jpg
