Go to Post When you get a vanity license plate with you team or robot name on it or some other FIRST reference. - Raul [more]
Unread 01-02-2014, 17:04
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Weird behavior in our code
We are having problems getting our pressure switch for the compressor working. Here's what's happening:
- When the robot is disabled and the code is deployed, I can see the pressure switch state by an indicator in Periodic Tasks.vi.
- When the robot is enabled, the state goes false, not changing no matter what the pressure switch reads.
It's like the robot just does not want to read the inputs we have in DIO on the sidecar while the robot is enabled.
Unread 01-02-2014, 22:43
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Weird behavior in our code
Can you post a picture of the code you are running? This can help us better identify the problem!
Per Audacia Ad Astra
Unread 02-02-2014, 00:31
False on a DIO means the signal is being pulled low. A properly wired pressure switch will do that when the pressure is too low and it is calling for the compressor to run.
What do you see the indicator doing when you completely disconnect the pressure switch? If it still says the switch state is false, there's something very wrong. Either the hardware (or the cRIO image) is faulty, or your code isn't reading the input properly.
Unread 02-02-2014, 01:55
If you remove the DB-37 cable from the digital sidecar, are all three power LEDs brightly lit?
Unread 03-02-2014, 13:44
Landonh12's Avatar
270 points
AKA: Landon Haugh
It is the example compressor code. I'm opening the Compressor in DIO 1 and Relay 1, and setting the RefNum to Compressor. In Periodic Tasks, I am doing a RefNum Get (Compressor) and feeding that into the Compressor Control Loop.
I'll check that today. I'll get back to you later.
BATT doesn't come on. 5V and 6V is on, though.
This is our 3rd Digital Sidecar. I highly doubt all 3 are bad. The new one we got in the KOP was bad because 6V wouldn't come on. We know we are supplying 6V because it showed up on 2 other Sidecars and we checked it with a multimeter.
Unread 03-02-2014, 13:57
So you have the Sidecar wired to the power distribution board at a pair of the 20/30a red/black wago connectors with a 20a breaker and it still isn't receiving power (no BATT LED)?
Once the sidecar is getting proper 12v power from the battery all three power LEDs will be brightly lit.
example - top DSC is with no 12v power, bottom is with 12v power
It's not going to work until you can get 12v into it.
Unread 03-02-2014, 16:27
Landonh12's Avatar
270 points
AKA: Landon Haugh
This is what we have now: http://m.imgur.com/Zo5pqK0
Looks like our electrical team wired it up in the wrong spot. It should come out of one of the 30A MAX ports with a 20A breaker, correct?
Unread 03-02-2014, 16:47
USFIRST and ScreenstepsLive web pages have all the info you need to wire the bot properly.
USFIRST.ORG "Power Connectivity Diagram"
http://www.usfirst.org/sites/default...icalLayout.pdf
DSC Excerpt from above:
http://www.chiefdelphi.com/forums/at...7&d=1389920308
WPI ScreenstepsLive "Wiring the 2014 FRC Control System"
http://wpilib.screenstepslive.com/s/...control-system
DSC excerpt from above:
http://www.chiefdelphi.com/forums/at...d=13914640 67
USFIRST.ORG "Data Connectivity Diagram"
http://www.usfirst.org/sites/default...gnalLayout.pdf
Name:	DSC power 2.jpg
Unread 03-02-2014, 17:27
Correct.
You can see that on Ether's first DSC link.
Unread 03-02-2014, 19:49
Please let us know if that fixes the issue.
Unread 04-02-2014, 07:58
Landonh12's Avatar
270 points
AKA: Landon Haugh
Yep, that fixed it. Thanks for the help!
