Go to Post I will read this blog, read your stories, learn from you, and be a better mentor because of you. You give me hope. Your diversity brings me joy. - Carolyn_Grace [more]
Unread 08-02-2003, 18:30
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Serial Shortening
Is it legal to cut the serial cable connecting radio to the RC and shorten it? I thought I saw a rule that said it was legal to shorten/lengthen some wires, but I can't find it now. Thanks in advance.
Unread 08-02-2003, 19:42
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
I wouldn't go to the trouble of actually cutting the cable, I would just get a shorter one or tiewrap the slack or something...
Unread 09-02-2003, 01:03
Clearly, if I had any sense at all, that's what I would do. But instead, I feel like creating extra work for myself. It's not like I don't have enough work already, it's that I behave in nonsensical ways. I'm compelled to cut the serial cable to make it the perfect length. The manual says it's acceptable to shorten/lengthen Control Cables with 3 conductors or fewer such as PWMs as long as the connections are insulated.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 14-02-2003, 22:06
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
if your still tracking this thread, we had the same issue, i simply wired a strait-thrugh 9 pin cable with a male and female DB9 from radio sha... I MEEN DIGIKEY! anyway it works fine, but if they make us take it out for the compitition we have a premade backup... - JACOB
Unread 14-02-2003, 22:21
Umm Errr...
make your own. its much prettier than having a splice in the middle of the premade ones.
1139 Alumni
Unread 14-02-2003, 23:38
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Re: Serial Shortening
It is illegal to cut these cables as they contain more than 3 wires. You either have to zip-tie them into a little bundle or make your own from scratch.
Unread 14-02-2003, 23:48
AKA: theshadow
FRC #0620 (WarBots)
Re: Re: Serial Shortening
You make it sound dreadfull, I went out to radioshack to get the connectors and then put the thing together (yes all 9 pins) in less then an hour... its not THAT bad
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
FOR SALE: Long serial cables Cheap!!! sanddrag General Forum 10 06-11-2002 15:39
