Go to Post It would also level the playing field by bringing the bottom up, rather than the top down. - russell [more]
Unread 01-02-2014, 14:15
jls667 jls667 is offline
None #2579
jls667 is an unknown quantity at this point
Autonomous with Mechanum Wheels
It looks like I got driving mechanum wheels working. How do I get autonomous working? I use command like the ones below.
drive.mecanumDrive_Polar(.5,0,0);
timer(1,0);
drive.mechanumDrive_Polar(0,45,0);
timer(1,0);
drive.mecanumDrive_Polar(0,0,0);
I get an error, "Output not updated often enough." Any ideas?
Unread 02-02-2014, 06:17
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Autonomous with Mechanum Wheels
That sounds like the motor safety mechanism is kicking in and stopping your motors because you are not setting the output powers quickly enough (the one second pause from your timer delay).
So, you have two choices. The simple solution is to disable the motor safety feature.
// Turn off drive safety feature as there are long delays between
// changing motor speeds during autonomous
drive.setSafetyEnabled(false);
// Your autonomous code
// Optionally turn drive safety feature back on (if you want it for teleop)
drive.setSafetyEnabled(true);
Alternatively, you can break your time delay up into smaller chunks.
Our team leaves the drive safety feature disabled for the entire match and rely on manual intervention to hit the Enter key when we need to disable a run away robot.
Unread 03-02-2014, 12:07
The first important question is whether you're using SimpleTemplate or IterativeTemplate. If you're using SimpleTemplate, then your only problem is Motor Safety. If you are using IterativeRobot, you will need to restructure your code to remove the delays.
Here's a description of motor safety: http://wpilib.screenstepslive.com/s/...safety-feature The example Java program disabled motor safety in autonomous and enables it in teleop. See http://wpilib.screenstepslive.com/s/...ot-programming
Unread 06-02-2014, 12:59
None #2579
I am using the SimpleRobot class. It turns out that I did turn safety off. My robot does nothing in autonomous. The robot works great in TeleOperator mode. I must have missed something else.
Unread 06-02-2014, 13:04
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Can you post your code including the method for autonomous? Also, please post it in CODE tags so it will be easier to read.
Unread 06-02-2014, 15:42
None #2579
Public void automous() {
myDrive.setSafetyEnabled(false);
myDrive.mecanumDrive_Polar(.5,0,0);
Timer.delay(1.0);
Unread 07-02-2014, 07:55
Flywheel Police
Timer.delay(1.0);
You have autonomous spelled wrong.
Is this what your code looks like, or is it spelled wrong in your code also?
public void autonomous() {
     Timer.delay(1.0);
Unread 07-02-2014, 14:21
None #2579
I made a different spelling mistake on my program. Thanks.
Unread 07-02-2014, 23:21
None #2579
I have another related question. I want to use the method myDrive.mecanumDrive.Polar(x,y,z) in my autonomous method. Please explain the three numbers x,y,z. What does each do to the robot?
Unread 08-02-2014, 00:11
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
RobotDrive#mecanumDrive_Polar() takes input in the form of polar coordinates, as opposed to RobotDrive#mecanumDrive_Cartesian() which takes Cartesian (Rectangular) coordinates. The three parameters for RobotDrive#mecanumDrive_Polar() are as follows:
Originally Posted by FRC Javadocs
magnitude - The speed that the robot should drive in a given direction.
direction - The direction the robot should drive in degrees. The direction and magnitude are independent of the rotation rate.
rotation - The rate of rotation for the robot that is completely independent of the magnitude or direction. [-1.0..1.0]
You can find information like this in the Javadocs in the sunspotfrcsdk directory.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
