Go to Post This thread should surface like this before every new season. It is motivating and inspiring. And jawdropping. - JaneYoung [more]
Unread 02-02-2014, 09:07
J. Stofflett's Avatar
J. Stofflett J. Stofflett is offline
FRC #0123
J. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura about
Re: Locking Mechanism for Catapult?
This works well for us.
http://www.mauriprosailing.com/us/1-...ts/HAR418.html
https://drive.google.com/file/d/0B3y...it?usp=sharing
Unread 02-02-2014, 10:04
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
We have prototyped a latch actuated with a short stoke cylinder. The prototype used a 1/2" diameter shaft supported on bearings to simulate a CAM roller. The latch was cut from 1/8" AL flat stock such that the latch would follow the radius of the shaft and go just over top dead center. The latch is also cut away from the shaft at an angle to allow the catapult to flex down when the ball enters.
We have not completed the competition version; however, have high confidence it will work reliably. If not, thanks to the posters for alternatives.
Unread 02-02-2014, 10:13
Could you post a picture or two? I can't quite get a mental image from your description.
Thank you.
