Go to Post we've got three years to perfect it. And then... who knows? - Amanda Morrison [more]
Unread 01-02-2014, 12:32
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
PWM Signal
We are running a 6 CIM Drive for the first time this year. We want the security of running each speed controller to a separate PWM port on the DSC but we don't have 6 to spare. Can we create a 3 way splitter cable to attach to each speed controller, and on the other end wire two PWM connectors in Parallel and attach it to 2 PWM ports? This photo should help clarify. That way we save 2 PWM ports and we have some redundancy in the electronics.
Is this a good, or horrible idea?
Unread 01-02-2014, 18:22
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: PWM Signal
Teams do that all the time. AndyMark even sells a Y cable for doing two at a time. I'm sure doing three Talons would be fine as well.
Unread 01-02-2014, 18:44
Re: PWM Signal
Did you notice that he is proposing to connect the two DSC outputs together?
see attached sketch
Name:	PWM cable.jpg
Unread 01-02-2014, 19:20
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Re: PWM Signal
Find it highly unlikely that only one port on your sidecar will fail and in a way that it would not interfere with the signal from a second. I also don't know how well the controllers would like having two signals sent to it all the time, Im guessing that the signals would not be exactly the same. Also I think it to be more likely for your pwm y cable to fail more than any port on the DSC, and adding to the number of pwms connected to each other will increase the probability of a connection coming loose.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 01-02-2014, 19:24
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Re: PWM Signal
I didn't catch that you were connecting multiple outputs of the DSC together. Just run the three Talons from a single DSC output and you'll be fine,.
Unread 01-02-2014, 19:54
Re: PWM Signal
I think you're probably right Dale. But this post by EricVanWyk from 4 years ago does seem to suggest that the number that can be supported is different for different models of controller.
Maybe Mike Copioli could weigh in here and let us know if he believes that 3 Talons will be OK being driven off one DSC PWM port.
Unread 01-02-2014, 20:32
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Re: PWM Signal
It's feeding into an optoisolator in each Talon out of a 330 ohm resistor in the DSC. The PWM output can source or sink 15ma. Most optoisolators turn on around 1.6ma. We've driven three Talons before with no issue but Mike might have thoughts about whether it's likely to be on the hairy edge.
Unread 01-02-2014, 21:26
Re: PWM Signal
Most likely so*. If there's a schematic, I haven't been able to find it.
Yes. There's a schematic for this.
With a dead short, yes.
The spec is available for the Jag, and it is guaranteed to turn on with 1.6 ma.. Since there's a 150ohm series resistance and a voltage drop across the LED, it requires about 1 volt to push that 1.6 ma through the LED.
So if you drive 3 Jaguars being driven by one DSC PWM port:
5 - 330*i - (150/3)*i - 0.7 = 0 . . . => .. i=11ma .. => .. 3.8ma per Jag
So it should work for 3 Jags... but I'm not sure about that 0.7 number; couldn't find a spec.
If you're reading this Mike, any info you'd be willing to provide would be appreciated. Don't want to speculate.
* http://www.chiefdelphi.com/forums/showpost.php?p=1127215&postcount=3
Unread 02-02-2014, 00:50
tStano tStano is offline
AKA: Sparks
tStano will become famous soon enough
Re: PWM Signal
With this fix, you're using 2 slots anyway, so why don't you just use a y-cable and a normal PWM for each side? As mentioned above, I can't see one port failing and not the other, although I'm sure its possible; just not likely enough really to worry about.
That is, If you don't just want to run the three PWMs off one port, which probably would work just fine, as discussed above.
Last edited by tStano : 02-02-2014 at 00:54. Reason: Added bit about one failing and not the other.
Unread 02-02-2014, 09:52
DonRotolo's Avatar
Back to humble
FRC #0832
Re: PWM Signal
I agree.
IF YOU DO run 3 off a single port, PLEASE post your results here so everyone else will know whether this will work or not. Thanks!
Unread 02-02-2014, 10:33
FRC #2791
Re: PWM Signal
Currently we are running three off of one port. It is working fine, I hope that it continues to work fine. We will post an update later in the season.
Thanks all.
Unread 02-02-2014, 10:57
Re: PWM Signal
My guess is that it will.
Does your team have access to an oscilloscope? If you want to be on the safe side, you can measure the voltage waveform (and magnitude) on the signal line in your PWM cable. It can give you some assurance that you've got adequate operating margin.
FWIW, I just found this note in the spec for the H11L1M optocoupler used in the Jaguar.
Unread 02-02-2014, 13:37
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
Re: PWM Signal
We've been running three Talons from one cable this season and haven't noticed anything unusual. It would be good to know if we're living on the edge, or are well within the normal operating capabilities.
Unread 02-02-2014, 14:33
Re: PWM Signal
The evidence is starting to mount that doing this should be OK, but yes you are wise to want to confirm that. I will trying sending a PM to Mike Copioli to alert him to this thread and see if he can help.
