Go to Post Frisbees [as next year's game piece]. That is all. - Frenchie461 [more]
Unread 02-02-2014, 14:23
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Re: Spikes are not working
Do you get any lights on the Digital Sidecar next to the relay pins?
Is the Digital Sidecar correctly powered, with battery voltage present on its power input and all three of the power LEDs brightly lit?
What pattern is the Robot Signal Light flashing when you have the robot enabled?
No, I do not get any lights on the digital sidecar next to the relay pins.
Also, the digital sidecar is correctly powered, we have nine victors on the robot which all work just fine.
The robot signal light flashes in its normal pattern, as if nothing were wrong with the robot.
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
