Go to Post But when it comes down to it, the best teams usually end up winning regardless. - Cory [more]
Unread 02-02-2014, 14:26
ShaneKent253 ShaneKent253 is offline
FRC #0253
ShaneKent253 is an unknown quantity at this point
Running a Double Ended Solenoid off of one Spike
Hello from Team 253,
We are wondering if we can connect a double ended solenoid to one spike. We have seen it done with two diodes like this:
We have also seen two separate solenoids wired to one spike like this and we are wondering if we can do the same exact thing but with a double ended solenoid.
Thanks for the help!!
Shane
Unread 02-02-2014, 14:27
Re: Running Two Separate Solenoids off of one Spike
http://www.chiefdelphi.com/forums/sh...hreadid=125674
Unread 02-02-2014, 14:34
FRC #0253
Haha, I see that I already posted a similar question today, I guess the main question is: Is a double ended solenoid considered two separate solenoids? If so then I see that it is legal.
Thanks,
Shane
Unread 02-02-2014, 15:28
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Running a Double Ended Solenoid off of one Spike
It looks like either method would work. Method 2 is shown in the spike user guide which is referenced on the kit parts of page. I would go with that method since it has First issued documentation.
Obviously it is a 12 V solenoid. 24 V ones won't work with a spike. Don't fire the A&B signals at the same time or you will confuse the valve.
