Go to Post The world isn't made out of Nerf, you will get scrapes and bruses, but you will get back up and continue on. If you watch out you can avoid the sharp edges. - Joe Matt [more]
Unread 02-02-2014, 16:21
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: Team 2471's ball shifting spool
Unread 02-02-2014, 16:22
yash101 yash101 is offline
AKA: null
Re: pic: Team 2471's ball shifting spool
Did you guys manufacture that yourself? That's a legit piece of engineering!
Unread 02-02-2014, 16:41
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
I second that. Looks completely professional, I would have guessed it was off the shelf. Care to share how you made it?
My comments do not reflect the views of associated teams.
Unread 03-02-2014, 03:57
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thanks, I wish we had the machines capable of making that in house. Thankfully we have a mentor who has access to a really nice lathe and knows someone with a really nice wire EDM machine.
The assembly has three major parts: the spool, the ball carrier, and the shifter rod.
The ball carrier is turned to its outer shape on a lathe, the holes for the ball bearings and a key way are cut on a mill.
The shifter rod is turned to the correct outer dimensions then the end is threaded.
The spool is turned on a lathe and a profile for interacting with the bearings is wire EDM'd.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
