Go to Post Flattery will get you everywhere. - nuggetsyl [more]
  #46   Spotlight this post!
Unread 13-01-2014, 13:20
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: [Ri3D] BOOM DONE. We're not done...
Could you please update us on what you have found out about this?
Working with the Vex folk to understand this. Reportedly, they sold a boatload of these last year with no complaints.
I've ordered AndyMark HD's as a backup in case. Backup #2 is to go with all omnis (like JVN's Blitzbuild robot but we have a CIM+MiniCIM per wheel -- shojuld be a screamer).
Dr. Joe
Team #88, TJ2
  #47   Spotlight this post!
Unread 13-01-2014, 13:40
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Dr Joe,
I have tried a couple of times, within the past two hours, to download the Boom Done - MCAD.zip files without success (receive error message). Has anyone else at CD been successful?
Thanks again for a great design. For small resource teams, your design is now our prototype for potential improvement (but don't hold your breathe for too long).
Regards,
FRC3548 Coach Marc Center
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
  #48   Spotlight this post!
Unread 13-01-2014, 15:05
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by marccenter View Post
Dr Joe,
Regards,
Hard for me to test because we are all on the same system here. Has anyone else had the same problem?
This is what works for me:
  1. Go here (there is some sort or error message here but ignore it)
  2. File menu > Download.
  3. BOOM DONE.
Team #88, TJ2
  #49   Spotlight this post!
Unread 13-01-2014, 15:10
magnets's Avatar
magnets magnets is offline
  3. BOOM DONE.
It works for me from this link. Thanks!
  #50   Spotlight this post!
Unread 13-01-2014, 15:12
magnets's Avatar
The team I'm with used these mecanums last year, and the rollers have a TON of play (more than a new wheel), but they seem to work, so no issue here after ~40 matches.
  #51   Spotlight this post!
Unread 13-01-2014, 15:14
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Dr. Joe,
I've pieced together what I could from the videos, and it sounds like you have a sharp IR sensor on board for ball detection, as well as some kind of acoustic sensor for measuring robot distance to the wall.
I tried digging through the java code you guys posted, but all I saw for distance measurements was based off the camera code/target detection.
If I've overlooked something please feel free to point me to the correct Java Class and I'll re-review.
Would you be able to provide any additional information on the sensor(s) used for ranging. I'm interested in knowing what make/model part was used and any usage notes (e.g. under what conditions did the sensor perform well/poorly).
Thanks, and great work.
http://team2168.org
  #52   Spotlight this post!
Unread 13-01-2014, 15:27
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Dr. Joe,
Congrats on winning the poll for best Ri3D robot!
The final vote was too close for comfort, given the capabilities you both demonstrated and explained.
I should have taken a class in marketing, because the second place robot certainly had a "wow" factor in their release video (cool lights, sound track, slow-motion). "Form before function?"
BTW, we're also interested in the sonar sensor you used. We've had mixed results with the Maxim devices (although we figured out some of the pitfalls).
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
  #53   Spotlight this post!
Unread 13-01-2014, 15:38
axial or radial? or both?
  #54   Spotlight this post!
Unread 13-01-2014, 15:53
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by otherguy View Post
Dr. Joe,
All the sonar stuff is on the Arduino. We currently don't send the distance data anywhere but the display. This was just an interim solution. Long term we want the CRIO to have access to the distance data. We also are thinking about some interference detection/avoidance methods. Stay tuned...
Dr. Joe
Team #88, TJ2
  #55   Spotlight this post!
Unread 13-01-2014, 16:58
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Dr. Joe
We will be doing a similar approach, but a bit backward to your approach. We already have the Arduino running the US sensor and displaying the relative distance via an addressable LED strip.
Our final design will have the cRio doing the actual distance measurements, that way it can position accurately by itself, and passing the distance info to the Arduino to display info to the driver. The display may end up on the Driver's Station, or on the robot, or both. All is still TBD.
  #56   Spotlight this post!
Unread 26-01-2014, 16:36
MikeZ MikeZ is offline
FRC #0624 (CRyptonite)
MikeZ has a spectacular aura aboutMikeZ has a spectacular aura about
Dr. Joe
Dr Joe
Great job and thanks for your posts. Question on the sonar. I noted in your specs and capability document a reference to a sonar horn/cone made from sheet metal. We have tried the same ultrasonic sensor will mixed results so would appreciate if you could elaborate a bit on your cone design and how it enhanced sensor performance. Many thanks.
Mike Zanghi
FIRST Team 624
CRyptonite Robotics
  #57   Spotlight this post!
Unread 26-01-2014, 20:19
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Dr. Joe
Joe,
Our sister team from Richmond used Vexpro mechanums last year, and broke an extremely large number of rollers off. In the end they broke so many that they put duct-tape on the things and used them as normal wheels because they were out of spares.
Now, I didn't build their robot so I can't say for certain that they had everything set up right. So I can't necessarily state that they weren't the cause of their own problems.
Are you seeing a lot of fractures at the point where the rollers meet the main body of the wheel?
  #58   Spotlight this post!
Unread 02-02-2014, 20:11
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
We used the the 6" VEXpro mecanums. We did not have any problems through 2 regionals and Worlds. Then we did demos and the wheels started breaking. Once one goes, they all start going. Either the had been weakened or once the one roller went, the others had uneven forces and they would all start breaking. We finally changed the demo bot to 4 standard wheels because we would lose a roller halfway through. At demos, the kids were more likely to run on uneven ground and start the cascade of breakages.
I would think they would last through regionals on even ground, just make sure you have a set of replacement wheels(and design for easy wheel changes) and extra rollers.
  #59   Spotlight this post!
Unread 04-02-2014, 11:37
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Working on a spec page but 15:1 is the short answer.
Please excuse my lack of intelligence, but aside from using the Green Cord to spare your motors, what stopped you from simply using AndyMark gearboxes with that or a similar reduction (like a pair of 8.75:1 toughboxes with reduces by 2:1 on the output)? Is there some other mechanical advantage to using the gigantic sprockets? Thanks!
  #60   Spotlight this post!
Unread 07-02-2014, 19:02
JohnFogarty's Avatar
AKA: @doctorfogarty
Toro Horns. You are not going to believe it: Schedule 80 PVC (thicker wall than Schedule 40). I heated up some 1/2" hex shaft and melted it in place so that a Versaplanetary shaft fits tight inside.
Dr. Joe
* which roughly stated is (6) #10 holes on a 1.875" bolt circle with a 1.125" center hole.
So. We're in our shop today trying to figure out a way to expand the 1/4" Schedule 80 PVC to fit onto the 1/2" hex shaft and it seems to be quite a challenge. How did you do it?
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
