Go to Post An inability to communicate your ideas effectively is a handicap you would be well served to strive to overcome. - Ether [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 30-01-2014, 22:40
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Practical 3D printed parts
Originally Posted by Wzup4021 View Post
we would like to use the 3D printer because this is only a mock up. this will not go on the actual robot.
You can download the step file from Andymark to get all of the layout and make any modifications you want and create your .stl file from there to print them. If you leave them thin they will most likely have a lot less stability than their metal counterparts.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
  #62   Spotlight this post!
Unread 30-01-2014, 22:42
We printed a wheel to fit inside a roller mechanism that has an opening for 3/8" hex shaft. Added our logo and some FIRST decorations just because we could.
Andrew Basse
  #63   Spotlight this post!
Unread 30-01-2014, 23:04
Fawnhugs's Avatar
Fawnhugs Fawnhugs is offline
Maya
FRC #1339 (Angelbotics)
Fawnhugs is an unknown quantity at this point
Our team has 3d printed VEXpro Gussets for our Versaframe. These have proven to be incredibly useful for prototyping and have held together our robot very well. With shortages of materials and unreliable shipping time, the gussets we printed have made a great substitution for the VEXpro ones. Only problem is that the holes are always a little bit too small but drilling them out is no problem.
Here: Click image for larger version
ID:	16029 You can see some of the gussets we have are non 3d printed for extra support but the colored ones we printed on our Makerbot.
  #64   Spotlight this post!
Unread 30-01-2014, 23:12
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
As promised, our winches.
This year's winch utilizes 3D printing pretty heavily - the spool is printed, as is the webbing guide. This let us quickly and easily put everything into a small package for use on the robot.
Last year's winch was all hand-made. First, we had to cut the sides for the spool. Then we had to get them bolted together and into some shaft collars to make them stay in place. Then we had to improvise a guide to try to keep the webbing straight... and it ended up occasionally getting off the spool and all tangled up.
ID:	16030  Click image for larger version
2016: Lake Superior WFFA
  #65   Spotlight this post!
Unread 02-02-2014, 16:10
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Originally Posted by eddie12390 View Post
Could you upload an example image of the CAD or of a real life example? That sounds like an interesting use of a printer.
The yellow one is last year's and the purple one is this year's new, more beefy, battery handle
We are still working on the printing. We are trying to make it more easy to print
ID:	16068  Click image for larger version
ID:	16069  Click image for larger version
  #66   Spotlight this post!
Unread 02-02-2014, 16:33
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
That's great! I thought of making something similar for our batteries a few weeks ago, but there is no room for them on our robot...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
  #67   Spotlight this post!
Unread 02-02-2014, 18:35
How do you put it on and take it off the battery? If I'm interpreting what I see correctly, it looks like you need a screwdriver (and likely a nontrivial amount of time).
  #68   Spotlight this post!
Unread 02-02-2014, 20:14
Slave to the bot
AKA: Chad Krause
Team Role: Driver
Yes, that is correct. Its not to hard to get it on, and it helps save your hand and makes it easier to carry the batter with, let's say, the driver controller
I will try and get the stl Out asap
  #69   Spotlight this post!
Unread 02-02-2014, 20:29
Nate Laverdure's Avatar
FRC #2363
Meaning it stays attached to the battery at all times, I guess. Very cool.
Also battery-related, I wish I had the 3D model for this.
  #70   Spotlight this post!
Unread 02-02-2014, 20:33
Mentor, LRI, MN RPC
Please make sure you note: Per R5, a handle like that is not considered part of your battery assembly, and must be included in your robot weight in all configurations used. Personally, I think it's a great idea to have a good way to carry the battery, but if you leave the handle on the battery when it's in the robot, it becomes difficult for inspectors to handle something like that within the rules as they are written. If that's the intent, I would recommend asking how it should be handled (pun not intended) on the Q&A.
  #71   Spotlight this post!
Unread 02-02-2014, 21:05
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
This year 4183 has had access to an laser cutter that is housed in the same work space as us, and it has been extremely useful. This year instead of ordering our gussets and waiting for a week before they come in and we decide we need something different, we have been able to make plywood gussets in minutes and immediately attach them. We have our practice bot held together by these plywood gussets.
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
  #72   Spotlight this post!
Unread 03-02-2014, 02:57
wesleyac's Avatar
wesleyac wesleyac is offline
Registered Luser
AKA: Wesley Aptekar-Cassels
FRC #1678 (Citrus Circuits)
wesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to behold
Not very practical (yet!?), but 1678 tested out some 3D printed wheels this off season.
See here.
Originally Posted by The programming team
Define "works."
  #73   Spotlight this post!
Unread 03-02-2014, 10:10
thmeans06 thmeans06 is offline
Drive Coach, IT Support, Mentor
FRC #0066
thmeans06 is an unknown quantity at this point
This year, the Battery Mounting Kit http://www.andymark.com/product-p/am-0477.htm was not included in the KOP and I wanted to print one. Before I spend time measuring it and drawing it in CAD (no CAD file on andymark's site) I wanted to see if anyone else had already created it and would be willing to share? Any help would be greatly appreciated!
  #74   Spotlight this post!
Unread 03-02-2014, 12:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
You can still find this item in the PTC 2013 Ultimate Ascent Kit of Parts.
I converted it to .stl the other day, I'll see if I can find it.
Edit: Here is the .stl file.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
  #75   Spotlight this post!
Unread 03-02-2014, 16:43
pfreivald's Avatar
AKA: Patrick Freivald
We made modular, stackable towers for our victors, with integrated pwm clips and zip-tie/strain relief holes.
Just got the first few assembled and thus far we're quite happy with them!
Name:	Victor Tower.png
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
