pic: Team 4096 - New Kicks
Re: pic: Team 4096 - New Kicks
Hopefully the inspectors don't call you out on your "Death Trap". Safety is important.
![]() Are those 4 CIMS in the kicker? Because it looks like 4 CIMS also in the mecanum. |
Those would appear to be two CIMs and two mini-CIMs in the kicker.
Also note I think your mecanums are on backwards. They are supposed to form an "X" from the top, not a diamond (imagine extending the pins of the rollers out. They should point towards the center of the robot.
Correct: http://www.chiefdelphi.com/forums/sh...5&postcount=10 Incorrect: http://www.chiefdelphi.com/media/photos/20664 |
You're correct if you're looking from the bottom, but you're looking from the top. |
Everywhere I've read says x on top, diamond on bottom. Does anyone know why this is? It seams kind of counter intuitive to me...
#7
Are you sure? Assuming force is applied along the roller axles, the vectors seem to work out better for turning (torque not equal to zero) when they form a diamond on the bottom.
#8
@Rule inspectors, looks like they're planning to have a pop-out box that covers the backswing of the hammer.
Thing is still terrifying , though. We're going to be staying well away from it ![]() |
#9
From Top: \.........../ \.........../ \.........../ ............. ............. /...........\ /...........\ /...........\ From bottom: /...........\ /...........\ /...........\ ............. ............. \.........../ \.........../ \.........../ |
#10
I believe the quote used in the past was
O from below make mecanum go |
#11
We used 8.45:1
