Solenoid Breakout Code Help
Hi CD!
I was wondering if anyone could take 5 minutes and briefly review our code for the Solenoid Breakout attached to the NI Module 9472. We code in C++ using Windriver Workbench. Thanks in advance! #include "WPIlib.h" #include "compressor.h" class RobotDemo : public SimpleRobot { RobotDrive Frankbot; // robot drive system Joystick leftjoy; Joystick rightjoy; Joystick joystick3; Relay Pulley; Relay piston1; Relay Arm; // PistonHelper Relay PistonHelper; //Actual Arm // Jaguar Winch; public: RobotDemo(void): Frankbot(1, 2), //these are the PWM ports leftjoy(1), rightjoy(2), joystick3(3), Pulley(2), piston1(4), Arm (5), PistonHelper (8) // Winch (4) { // usermessages = DriverStationLCD::GetInstance(); // Camera->WriteResolution(AxisCamera::kResolution_160x120 ); // Camera->WriteCompression(20); // Camera->WriteWhite // Balance(AxisCameraParams::kWhiteBalance_FixedIndoo r); // Camera->WriteMaxFPS(30); // Camera = &AxisCamera::GetInstance(); // myRobot.SetExpiration(0.1); // test } void Autonomous(void) { Compressor *c = new Compressor(1, 1); c->Start(); } void OperatorControl(void) { Solenoid*solenoidOne; Solenoid*solenoidTwo; solenoidOne = new Solenoid(8,1); solenoidTwo = new Solenoid (8,8); int up = 4; int down = 5; int WinchIn = 2; int WinchOut = 1; int ArmIn = 1; int ArmOut = 2; int On = 6; int Off = 3; int ArmUp = 2; int ArmDown = 1; int Sol1 = 3; int Sol2 = 4; static float speedModifier = 1.00; // static float winchspeed = 1.00; Compressor *c = new Compressor(1, 1); c->Start(); Frankbot.SetSafetyEnabled(true); while (IsOperatorControl()) { if(leftjoy.GetRawButton(Sol1)){ solenoidOne->Set(true); solenoidTwo->Set(false); } else{ solenoidOne->Set(false); solenoidTwo->Set(true); } } } }; START_ROBOT_CLASS(RobotDemo); |
