Go to Post Give me enough gearboxes and I'll move the world. - SenorZ [more]
Unread 03-02-2014, 12:01
valeriemoore valeriemoore is offline
FRC #2022
valeriemoore is an unknown quantity at this point
What bolts fit in the AM14u Drivebase?
What bolts fit into the mounting holes on the AM14U Drivebase? Not the bolts for assembling the frame, but the holes for mounting. Specs or a part number would be greatly appreciated.
Unread 03-02-2014, 12:05
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
I'm not completely clear on what you're referencing. Are you talking about the bolts for mounting a transmission?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Re: What bolts fit in the AM14u Drivebase?
The majority of the holes are .200" and are designed I believe for a #10 fastener. They can also be drilled for out for something larger like 1/4-20.
Unread 03-02-2014, 12:06
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Which holes? We're using AndyMark's 10-24s for the very top holes. for the bottom holes (the little lip towards the inside) I think we're using 1/4" bolts.
I know these work, not sure if they're the exact fit, I didn't really try hard to confirm this, because I was not going to go back to home depot for a fifth time. I'll probably be able to confirm tonight (but I'm sure someone will respond by then).
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 03-02-2014, 12:11
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
The holes across the top of the side plates and along the top of the cross brace extrusions are all .2" - thus a number 10 screw fits nicely (the CAD drawing I have for the cross brace measures .21, but that may be an error)
The holes around the bottom of the inner plate and the cross brace are .28" - thus fit a 1/4" screw perfectly.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
