Go to Post but yea. people have this perception of robots as like, the terminator. you don't have to be a super genius to do this stuff. - christina_omg [more]
Unread 03-02-2014, 10:56
TechWarlock TechWarlock is offline
Programming Dude
AKA: Jacob
FRC #1396 (Pyrobots)
TechWarlock is an unknown quantity at this point
Solenoid Breakout Code Help
Hi CD!
I was wondering if anyone could take 5 minutes and briefly review our code for the Solenoid Breakout attached to the NI Module 9472.
We code in C++ using Windriver Workbench.
Thanks in advance!
#include "WPIlib.h"
#include "compressor.h"
class RobotDemo : public SimpleRobot
RobotDrive Frankbot; // robot drive system
Joystick leftjoy;
Joystick rightjoy;
Joystick joystick3;
Relay Pulley;
Relay piston1;
Relay Arm; // PistonHelper
Relay PistonHelper; //Actual Arm
// Jaguar Winch;
public:
RobotDemo(void):
Frankbot(1, 2), //these are the PWM ports
leftjoy(1),
rightjoy(2),
joystick3(3),
Pulley(2),
piston1(4),
Arm (5),
PistonHelper (8)
// Winch (4)
// usermessages = DriverStationLCD::GetInstance();
// Camera->WriteResolution(AxisCamera::kResolution_160x120 );
// Camera->WriteCompression(20);
// Camera->WriteWhite
// Balance(AxisCameraParams::kWhiteBalance_FixedIndoo r);
// Camera->WriteMaxFPS(30);
// Camera = &AxisCamera::GetInstance();
// myRobot.SetExpiration(0.1); // test
void Autonomous(void)
Compressor *c = new Compressor(1, 1);
c->Start();
void OperatorControl(void)
Solenoid*solenoidOne;
Solenoid*solenoidTwo;
solenoidOne = new Solenoid(8,1);
solenoidTwo = new Solenoid (8,8);
int up = 4;
int down = 5;
int WinchIn = 2;
int WinchOut = 1;
int ArmIn = 1;
int ArmOut = 2;
int On = 6;
int Off = 3;
int ArmUp = 2;
int ArmDown = 1;
int Sol1 = 3;
int Sol2 = 4;
static float speedModifier = 1.00;
// static float winchspeed = 1.00;
c->Start();
Frankbot.SetSafetyEnabled(true);
while (IsOperatorControl())
if(leftjoy.GetRawButton(Sol1)){
solenoidOne->Set(true);
solenoidTwo->Set(false);
else{
solenoidOne->Set(false);
solenoidTwo->Set(true);
START_ROBOT_CLASS(RobotDemo);
Unread 03-02-2014, 11:28
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Solenoid Breakout Code Help
You should upload it to Pastebin or something similar for easier interpreting. It's hard to keep of brackets without any spacing.
Unread 03-02-2014, 11:56
Programming Dude
AKA: Jacob
Aside from the brackets is there anything else, i've been playing around with this code and i cant seem to get it to work at all, Thank You
Unread 03-02-2014, 12:15
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
I'm not sure as it's too difficult to read in its current state.
Unread 03-02-2014, 12:19
Post Re: Solenoid Breakout Code Help
Hint: surround your code with [ code] and [ /code] tags. It'll preserve whitespace that way.
What do you expect these two lines to do? In particular, what is the first "8" supposed to represent?
		else{
This looks like a job for a dual solenoid instead of two single solenoids.
Unread 03-02-2014, 12:26
Programming Dude
AKA: Jacob
the 8 is supposed to represent the slot we put the NI 9472 into, and yeah we are using a double solenoid
Joystick leftjoy;
Joystick rightjoy;
Joystick joystick3;
Jaguar Flipper;
Relay piston1;
Solenoid sol1;
Solenoid sol2;
// Jaguar Winch;
public:
RobotDemo(void):
leftjoy(1),
rightjoy(2),
joystick3(3),
Flipper(7),
piston1(6),
Arm (5),
PistonHelper (8),
sol1(3, 1),
sol2(3, 2)
public:
RobotDemo(void):
sol1(3, 1),
sol2(3, 2)
if(leftjoy.GetRawButton(sol)){
sol1.Set(true);
sol2.Set(false);
else if(leftjoy.GetRawButton(sol4)){
sol2.Set(true);
sol1.Set(false);
else {
sol1.Set(false);
sol2.Set(false);
i made some adjustments, but the code still doesnt work
Unread 03-02-2014, 12:32
I think you're working from documentation that is out of date by many years.
The first parameter doesn't specify the slot number in the chassis. It specifies the "module number", which is either 1 (for the first module of a given type) or 2 (for the second module). If you're putting your NI 9472 module in slot 3, it's module number 1. If you're putting it in slot 4 of a 4-slot cRIO or slot 7 of an 8-slot cRIO, it's module number 2.
Slot 8 of an 8-slot cRIO is always empty.
Unread 03-02-2014, 12:41
Programming Dude
AKA: Jacob
Thanks so much everyone! We got it working! My team and I appreciate all of your help!
Unread 03-02-2014, 15:47
cgranata cgranata is offline
Team Captain
Team Role: Electrical
cgranata is an unknown quantity at this point
Thank you Alan for your quick reply to the matter!! I appreciate you taking the time to read through our code (even though it was messy). Thanks for letting us know about the [code] tag!
