Go to Post Invest our time in enhancing the process of conceiving, designing, testing and deploying the game - billylo [more]
Unread 03-02-2014, 09:50
zcohen's Avatar
zcohen zcohen is offline
AKA: Zac
FRC #1111 (Power Hawks)
zcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to behold
What stock to store for mill/lathe work?
This past summer we bought a mid-sized manual mill and metal lathe. I've worked on mills and lathes extensively in the past, so I was able to get the appropriate tooling, but I'm having trouble coming up with a list of stock to carry to accomplish most tasks that we would need. So what does your team carry in terms of stock? I know it depends greatly on what you do as a team, but if you could still list what you get, we could use it as a starting point for our team.
Zachary Cohen
Team 1111 head mentor 2012-
Team 1712 mentor 2007-2012, 2006 alum
Technology and Engineering teacher
PLTW, STEM Magnet School
South River High School
Unread 03-02-2014, 10:23
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: What stock to store for mill/lathe work?
For the lathe:
- Material to make spacers (PVC pipe works great!)
- Material to make standoffs
For the mill:
- solid aluminum stock (bar and plate of various thickness)
- Other normal aluminum stock your team normally uses
For our situation, it's really not an issue to stop by a local Discount Steel and get whatever we need... and once we get it, we have plenty left over in stock. We've found for our team that having a mill and lathe isn't about the materials you have for it - just about everything we've used on it is stuff we already had sitting around. It's about the increased capabilities it gives you in shaping those materials perfectly or consistently for the robot (for example, it's a lot easier to make 4 standoffs that are all the same length using a mill or lathe than it is to do so with a band saw).
2016: Lake Superior WFFA
Unread 03-02-2014, 10:38
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
For the lathe, we mostly use:
-1" dia. aluminum rod
-2" dia. aluminum rod (less frequently)
-1/2" dia. aluminum rod
-1/2" dia. aluminum and steel hex shaft
-2" pvc tubing
-various other sizes of pvc and delrin.
For the mill we primarily use:
-Aluminum billet
-1"x1"x.125" aluminum square tubing
-1"x1"x.0625" aluminum square tubing
-.25" aluminum plate
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 03-02-2014, 11:26
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Originally Posted by zcohen View Post
This past summer we bought a mid-sized manual mill and metal lathe... <snip> So what does your team carry in terms of stock? I know it depends greatly on what you do as a team, but if you could still list what you get, we could use it as a starting point for our team.
For the mill:
1x1x1/6 wall box tubing (6061-T6)
1x1x1/8 flange angle (6061-T6)
2x2x1/8 flange angle (6061-T6)
3x3x3/16 flange angle (6061-T6)
1/2 x 1 UHMW bar
1/4 x 4 UHMW bar
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 03-02-2014, 11:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
For us this is a totally loaded question as we've probably used 30 different sizes of stock so far this year, in addition to a bunch of stuff we have stocked that we haven't used yet or have used in the past.
This is what we've purchased this year:
Size Length Alloy Quantity
.090"x48"x144" 6061-T6 1
1"x1"x.125" Tube 24' 6061-T6 4
1"x1"x.063" Tube 24' 6061-T6 7
1"x2"x.125" Tube 24' 6061-T6 3
1"x2"x.063" Tube 24' 6061-T6 6
.75"x.75"x.063" Tube 24' 6061-T6 3
.5"x.5"x.063" Tube 24' 6063-T6 2
.063"x1" Bar 12' 6061-T6 2
.125"x3" Bar 12' 6061-T6 2
.125"x4" Bar 12' 6061-T6 4
.125"x2" Bar 12' 6061-T6 2
.125"x1" Bar 12' 6061-T6 1
.1875"x2" Bar 12' 6061-T6 2
.1875"x3" Bar 12' 6061-T6 1
.1875"x4" Bar 12' 6061-T6 2
.25"x2" Bar 12' 6061-T6 2
.25"x4" Bar 12' 6061-T6 2
.25"x6" Bar 12' 6061-T6 1
.375"x1" Bar 12' 6061-T6 1
.5"x1" Bar 12' 6061-T6 1
1" square bar 12' 6061-T6 1
1"x.25" bar 12' 6061-T6 1
1"x1.25" bar 12' 6061-T6 2
1.25" square bar 12' 6061-T6 1
1.5" square bar 12' 6061-T6 1
1.25"x2" Bar 12' 6061-T6 1
1.25"x3" Bar 12' 6061-T6 1
2"x4" Bar 12' 6061-T6 1
.750"x.063" Tube 24' 6061-T6 3
1" x.063 Tube 24' 6061-T6 3
We also commonly use 1" round bar, 2.25" round bar and a bunch of other rectangular barstock sizes.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2014, 12:51
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Cory,
That is an impressive list!
Question for you, is this a typical amount of stock purchased for 254 for a season? I'm looking at some of the quantities and it's pretty daunting. Almost 200 feet of 1"x1"x.063" Tube? That seems to me like a ton!
Maybe it's just the game this year. I'm impressed when my kids work through just 20 feet of 1"x1"x.063" Tube!
Does 254 keep records on an spread sheet of all stock material purchases? Seems like your list was copy paste
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 03-02-2014, 12:54
AdamHeard's Avatar
Lead Mentor
Originally Posted by Michael Corsetto View Post
Cory,
-Mike
I can send you ours, it's similar qty.
We build lots of spares, and tubing gets eaten up fast. We seem to alternate between 2x1 and 1x1 seasons, but easily go through 100' of 1/16" wall each year.
We pay per pound, and it's relatively cheap (free shipping by truck as well).
Unread 03-02-2014, 13:02
That would be great!
Are you purchasing through Coast Aluminum? We just recently started buying from them and have been pleased with the pricing and next-day free shipping. Just got into the large-quantity production game, so we're still learning
AdamHeard's Avatar
Lead Mentor
Yes, we love dealing with them as well.
It's actually cheaper in the long run to order all these random sizes you might not need, and then always have a variety of surplus on hand to design around.
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Also, for lightweight shafting and spacers, Igus sends out some 5/8" linear bearing stuff every year. 5/8", 1/2", and 3/8" Igus shaft is a staple for us, the ceramic coating makes it really easy to slide through stuff. It is also smoother and holds better tolerance than regular aluminum in our opinion. Its good looking, and easy to machine the inside, just be careful when cutting the ceramic coating. Oh, and lots of 1x1, 1x2, and 1.25x2.5 box tube as well as all sorts of angle sizes (mostly 1x1) are really nice to have.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 03-02-2014, 13:12
Good to know!
+1 for Coast Aluminum, in one of our first orders we only wanted a 4x8 sheet of .125" 6061, and while they typically sell in 4x12 sheets, they made an exception for us. A great company!
Unread 03-02-2014, 14:41
Cory's Avatar
AKA: Cory McBride
Cory,
-Mike
This is pretty typical. We have probably 4x this in inventory from previous years in assorted sizes. Some of this will likely last until next year also.
I don't keep an inventory of what we have in stock, but I did make a spreadsheet to organize what I needed to get quoted.
We too use Coast Aluminum. Pricing is pretty good, but after 8 years their truck driver still can't understand that we are not available at 7 AM in the morning to accept deliveries when they show up to the real NASA shop with their metal.
2001-2004: Team 100
Unread 03-02-2014, 16:31
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
To add to the above suggestion:
These are good for shafts and spacers that we use regularly.
.750"x6ft delrin
1"x6Ft delrin
.5" hex 12ft
Thank-you 294 & 67
www.bobcatrobotics.org
