Re: Weird behavior in our code
This is our 3rd Digital Sidecar. I highly doubt all 3 are bad. The new one we got in the KOP was bad because 6V wouldn't come on. We know we are supplying 6V because it showed up on 2 other Sidecars and we checked it with a multimeter. |
So you have the Sidecar wired to the power distribution board at a pair of the 20/30a red/black wago connectors with a 20a breaker and it still isn't receiving power (no BATT LED)?
Once the sidecar is getting proper 12v power from the battery all three power LEDs will be brightly lit. example - top DSC is with no 12v power, bottom is with 12v power It's not going to work until you can get 12v into it. Last edited by Mark McLeod : 03-02-2014 at 14:06. |
Looks like our electrical team wired it up in the wrong spot. It should come out of one of the 30A MAX ports with a 20A breaker, correct? |
USFIRST and ScreenstepsLive web pages have all the info you need to wire the bot properly. USFIRST.ORG "Power Connectivity Diagram" http://www.usfirst.org/sites/default...icalLayout.pdf DSC Excerpt from above: http://www.chiefdelphi.com/forums/at...7&d=1389920308 WPI ScreenstepsLive "Wiring the 2014 FRC Control System" http://wpilib.screenstepslive.com/s/...control-system DSC excerpt from above: http://www.chiefdelphi.com/forums/at...d=13914640 67 USFIRST.ORG "Data Connectivity Diagram" http://www.usfirst.org/sites/default...gnalLayout.pdf Last edited by Ether : 03-02-2014 at 17:05. Reason: added links |
You can see that on Ether's first DSC link. Last edited by Mark McLeod : 03-02-2014 at 17:30. |
Please let us know if that fixes the issue.
#7
Yep, that fixed it. Thanks for the help!
