Go to Post When I'm hiring an intern "Award Winning VRC Notebook" isn't applicable. But "Award winning technical documentation" sure is. - Andrew Schreiber [more]
Unread 02-02-2014, 17:23
cgranata cgranata is offline
Team Captain
FRC #1396 (Pyrobots)
Team Role: Electrical
cgranata is an unknown quantity at this point
Solenoid Breakout Wiring
Hi Chief Delphi -
This year my team and I would like to use the Solenoid Breakout (am-0868) attached to NI Module 9472 to trigger a double solenoid (extend and compress a piston shaft) instead of using multiple Spike relays. However, I could not find a clear diagram anywhere that specifically details how a pneumatic solenoid is to be connected to the breakout.
I have seen diagrams like this one here: http://team358.org/files/pneumatic/D...iring.jpgBelow, however, I cannot tell which color wire goes where and on which pin on the breakout.
I have attached a diagram of how the solenoid should be wired up to the breakout (from my understanding).
Can someone else confirm or correct me?
Thank you in advance for your help! My team and I greatly appreciate it!
Name:	Solenoid Diagram.jpg
Unread 02-02-2014, 17:25
Jared's Avatar
Jared Jared is offline
Re: Solenoid Breakout Wiring
That's correct. Just make sure that the solenoid breakout board is powered by the 24 volt supply on the PDB if you're using a 24 volt solenoid.
Unread 02-02-2014, 17:53
The LabVIEW FRC examples have clear wiring diagrams, and there are examples to cover all of the most common FRC items. Even if you don't program in LabVIEW, it may be worth your time to install it and poke around the examples.
Unread 02-02-2014, 18:55
Team Captain
Thanks Jared for confirming our wire diagram!
Joe - These diagrams are within the Labview programming software? Also, do you agree with Jared that the diagram for wiring a solenoid to the breakout is correct?
Unread 02-02-2014, 19:10
Yes and Yes.
Unread 03-02-2014, 02:09
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Yes, that's how you wire it.
We bought the VexPro manifold and valves last year, and made a cable to feed all the solenoid outputs to the manifold for neater wiring. This year it'll be simpler since there aren't so many air cylinders needed to play the game.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 03-02-2014, 15:59
Team Captain
Does this piece here: http://www.vexrobotics.com/catalog/p...lery/id/25906/, get mounted to one of these: http://www.vexrobotics.com/catalog/p...6/image/28706/.
Unread 04-02-2014, 08:42
Yes,
But you need the plates to close off the unused ports on the manifold. Please be sure to wire +24 volts to the power common on the solenoid module in order to control 24 volt solenoids. No power means the solenoids will not work.
