Weird behavior in our code
We are having problems getting our pressure switch for the compressor working. Here's what's happening:
- When the robot is disabled and the code is deployed, I can see the pressure switch state by an indicator in Periodic Tasks.vi. - When the robot is enabled, the state goes false, not changing no matter what the pressure switch reads. It's like the robot just does not want to read the inputs we have in DIO on the sidecar while the robot is enabled. |
Re: Weird behavior in our code
Can you post a picture of the code you are running? This can help us better identify the problem!
False on a DIO means the signal is being pulled low. A properly wired pressure switch will do that when the pressure is too low and it is calling for the compressor to run.
What do you see the indicator doing when you completely disconnect the pressure switch? If it still says the switch state is false, there's something very wrong. Either the hardware (or the cRIO image) is faulty, or your code isn't reading the input properly. |
If you remove the DB-37 cable from the digital sidecar, are all three power LEDs brightly lit?
This is our 3rd Digital Sidecar. I highly doubt all 3 are bad. The new one we got in the KOP was bad because 6V wouldn't come on. We know we are supplying 6V because it showed up on 2 other Sidecars and we checked it with a multimeter. |
So you have the Sidecar wired to the power distribution board at a pair of the 20/30a red/black wago connectors with a 20a breaker and it still isn't receiving power (no BATT LED)?
Once the sidecar is getting proper 12v power from the battery all three power LEDs will be brightly lit. example - top DSC is with no 12v power, bottom is with 12v power It's not going to work until you can get 12v into it. Last edited by Mark McLeod : 03-02-2014 at 14:06. |
#7
Looks like our electrical team wired it up in the wrong spot. It should come out of one of the 30A MAX ports with a 20A breaker, correct? |
#8
USFIRST and ScreenstepsLive web pages have all the info you need to wire the bot properly. USFIRST.ORG "Power Connectivity Diagram" http://www.usfirst.org/sites/default...icalLayout.pdf DSC Excerpt from above: http://www.chiefdelphi.com/forums/at...7&d=1389920308 WPI ScreenstepsLive "Wiring the 2014 FRC Control System" http://wpilib.screenstepslive.com/s/...control-system DSC excerpt from above: http://www.chiefdelphi.com/forums/at...d=13914640 67 USFIRST.ORG "Data Connectivity Diagram" http://www.usfirst.org/sites/default...gnalLayout.pdf Last edited by Ether : 03-02-2014 at 17:05. Reason: added links |
#9
You can see that on Ether's first DSC link. Last edited by Mark McLeod : 03-02-2014 at 17:30. |
#10
Please let us know if that fixes the issue.
#11
Yep, that fixed it. Thanks for the help!
