Go to Post Have you been formally diagnosed as a masochist, or are you just a mentor? - GeeTwo [more]
Unread 03-02-2014, 15:19
TylerStaudigel's Avatar
TylerStaudigel TylerStaudigel is offline
FRC #0144 (R.O.C.K)
TylerStaudigel is an unknown quantity at this point
Question Button to control motor?
I need help to figure out a way to make a Boolean true false control a motor. I only need the motor to run at one speed and needs lots of help.
Unread 03-02-2014, 15:22
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: Button to control motor?
Use the express vi for true and false or a case structure with a constant in it to control your motor output. I don't have LabVIEW on me, so I can't show you right now.
Unread 03-02-2014, 16:35
It sounds like you just want to use a Select (on the Programming->Comparisons palette).
Here's an example using a couple of Selects to set motor speeds.
This particular example maintains the last speed chosen by button until overridden by a new button press and it's compatible with the Motor Safety Config if you want to use that:
Using Case statements looks like this (replace the Solenoid Sets with Motor Sets).
This method isn't compatible with the Motor Safety Config:
