Go to Post Wisdom shared is priceless, isn't it? And timeless. - JaneYoung [more]
Unread 01-02-2014, 20:51
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Constants from a text file
What are the advantages of getting constants from a text file?
Unread 01-02-2014, 21:09
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Constants from a text file
Off the top of my head
  1. No redeploying every change
  2. Easy to change settings from non-programming computer
  3. Less buggy than Smartdashboard or Preferences
  4. Easy to delete, reset, change
All opinions are my own.
Unread 01-02-2014, 21:35
AKA: Alex
How do you move your changes to the cRIO without redeploying?
Unread 01-02-2014, 23:09
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
If you use an FTP client like FileZilla, you can easily edit the constants file from the driver station and upload it to the cRIO. Then you have a method in your code that reads the new values from the file and updates your program accordingly. No recompiling necessary.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 03-02-2014, 11:15
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Also, if you're interested, I made a tool in C# for managing a Constants file fairly easily. It has the ability to parse a Constants file using the Cheesy Poofs format (each key and value on a new line delimited by an =) and can upload to the robot via FTP.
Unread 03-02-2014, 16:46
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Also, Windows has built-in support for FTP network locations.
You can add a ftp location (like ftp://10.xx.yy.2, your team's cRio) to the Computer (the location that comes up when you press WinKey+E, then just right click in empty space and select "Add a network location") so you can just browse and edit files through the standard explorer interface, no special client needed.
Unread 03-02-2014, 17:07
AKA: Joel Gallant
Was not aware of this. Thanks for the tip!
