Go to Post This system sucks more than our ball possession system. - IndySam [more]
Unread 30-01-2014, 14:01
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Help: Torque to Linear force conversion
Originally Posted by pfreivald View Post
You'll likely want a ratcheting system to take the load before you do that....
I'm afraid that this season we're going to see a lot of shifting winches that work well at first, and then suffer a bad case of broken teeth and sadness.
Back in 2010, ratchet failure due to broken/gouged teeth was the biggest problem our robot faced (well, second-biggest; our ratchet-tooth-click-counter approach to setting the kicker power was probably the biggest). Our kicker was supremely powerful (could score from the rear zone), but I've always avoided similar mechanisms since then for just that reason. Disengaging teeth under that much force without damaging them is not a trivial matter.
"The breakfast of champions!"
Unread 30-01-2014, 14:02
pfreivald's Avatar
AKA: Patrick Freivald
We're using a 3/8" stainless ratchet and pawl. What were you using?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 30-01-2014, 14:05
AKA: Eli Barnett
Something similar. I can snap a picture of the assembly and the damage and upload it (either later today or tomorrow) if you'd like.
We were disengaging our pawl to release our kicker, and the primary failure point was the pawl gouging out the ratchet teeth over time.
Unread 30-01-2014, 15:16
pfreivald's Avatar
Yeah, I'd love to see it.
Team 1551
I write books, too!
Unread 30-01-2014, 16:16
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Relieve the load on the teeth before releasing the pawl.
You designed to have enough power to pull it back? Pull it back a half tooth more while disengaging the pawl.
Similarly, if using a dog gear method... Drive the motor forward and backdrive while pulling the dog.
Unread 03-02-2014, 16:00
AKA: Eli Barnett
Here's a picture of the ratchet. You can see two severely gouged teeth, and these are on the lighter side of the damage we saw that year (we regularly rotated/swapped out ratchets as the teeth became useless). The pawl, too, took a beating in that mechanism, but I don't have it to show as it appears to have been lost.
http://imgur.com/8kZIYzK
To give a reference for the amount of force we were using on this thing, here's a shot where you can make out two of the (very heavy-duty) springs we used to power it:
http://www.flickr.com/photos/robotproject/5049734546/
In this picture it is set up for half-power, our full-power setup used four springs.
Alas, we could not do this as we used the same motor to both tension and release our ratchet.
Unread 03-02-2014, 16:42
pfreivald's Avatar
Is that aluminum?
Team 1551
I write books, too!
Unread 03-02-2014, 16:46
AKA: Eli Barnett
Is that aluminum?
I had thought it was steel, but looking closer at the pic it might be aluminum. I'll check.
