| Thread Tools |
Rating:
Display Modes |
#61
Re: VEXPro 2014 Product Initial Impressions
The three CIM DS gearbox confuses me. There is 1.316" between the plate and the gear closest to the plate, and there is nothing in this space. I understand why this room is useful if you're looking to add a PTO with a pulley, but I don't see why that extra space is there in the normal model. The could probably sell spacers that are 1.25" shorter, and have shorter shafts. |
#62
There are valid reasons for all the points you're raising, and your assumption that because you do not immediately understand them they must be silly/wrong is unfair. |
#63
Have you really seen a dog fail because the teeth didn't have radiused corners? I haven't. The weakest portion of a dog is the threaded hole. If anything the corner that you want radiused is at the base of the tooth, not the vertical edges. We have run unradiused edge dogs with zero issue. Perhaps you should consider applying to VEX and then you can design their products? |
#64
How much clearance do you run for a 1.125 flanged bearing? Did this change with the loctite? I seem to recall you using some small fasteners to retain bearings as well. Any insight would be appreciated.
#65
1.) We are doing a drive system where the wheels are driven, by chains, so that the sprockets run through the gearbox. We are using #25 chain and we have about 0.75" extra room. I think the extra space is for a team who wants to use a WCD with two 15 mm belts, as the space is slightly bigger than 30 mm. 2.) Why is the shifting slot longer than the travel of the cylinder? Does anybody know the advantage to having this be around 2x longer than a traditional setup? 3.) The traditional dog gear enters into the gear 0.125", so that you can have a 0.125" pocket in a 0.375" gear while keeping 0.25" remaining for a normal sized bearing. The vex dog gear has the bearing sticking out the back a little bit so that there is more engagement between the dog and the gear. When doing this, you loose the advantage of having the flange on the bearing. Does anybody know why this is? 4.) Why aren't there fillets on the dog/dog gear? I'm not talking about the ones on the outline of the dog pocket, but between the face of the gear and the vertical face of the pocket. A while ago, I made some of these dogs out of steel. Switching to a ball nose endmill and getting even a small radius on all the corners fixed our shattering dog problem. |
#66
When we bought our gear, it said nowhere that a bearing would come with it. I'm not complaining about our free hex bearing, but we planned on putting a not-hex bearing in the gear. Normally we use 1.1245 holes, because at that size, there isn't much slop in the fit. The vex bearing bore on one gear was 1.13. Quote:
Yes, our kicker in 2010. The problem went away after using a ball nose endmill. Do you really use an endmill with no radius to cut your dog gears? Again-I think vex products are among the best we've seen from an FRC supplier, but I'm just curious as to why some parts are the way they are. |
#67
I am slightly disappointed in the 6" mecanums. We bought a set in hopes to get the better traction then the AM ones. But within only 2 hours of driving and testing, we have numerous rollers that the axle/pin have come very loose. The Return On Investment of these wheels are horrible. We have since switched over to a set from AM, but have lost 4 lbs in the process of doing so.
#68
We haven't noticed any performance issues; but now concerned with the reliability of the wheels if you are saying this isn't normal. |
#70
Paul |
#71
Will do, we also ordered 10 jaguars the other week, when we opened the box to use them this weekend. We noticed that 5 were not operational.
