Go to Post Half your robot could be broken, some drive chains snapped, a drive motor burned out, etc... and your WCD will still be trucking. - AdamHeard [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 03-02-2014, 19:05
RobotDoktor's Avatar
RobotDoktor RobotDoktor is offline
Cat Herder
FRC #4265 (Secret City)
Team Role: CAD
RobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really nice
Re: Practical 3D printed parts
We made a battery mount that is the same dimensions as the Andymark one. The model is designed for 3d printing and is very durable, it can hold 10lbs no problem. The STL is here and the Solidworks part is here
Here an example printed in Stratasys VeroRigid plastic. You should have no problem with other plastics though.
Full disclosure: I am not a robot, a doctor, or a German.
  #77   Spotlight this post!
Unread 04-02-2014, 11:08
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
We use our 3D Printer for both our FRC team, along with the the FTC Team. Right now though, the FTC bot has more 3d prints than the FRC bot does.
Just seems easier to use it for an FTC bot then a FRC bot.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
  #78   Spotlight this post!
Unread 04-02-2014, 12:23
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Parts made so far with the 3D printer for use on our final robot:
- Battery Mount
- Camera Mount
- Drive mount with bearing that holds our wheel + gearbox together (not load bearing)
- Custom boxes to hold gyro, other sensors, beaglebone controller
- Custom-angle brackets
- Hub for the Denso window motor
Planned usage of more custom parts:
- Wire harnessing
- Control System shielding
- Possibly pneumatic system mounting
Can post photos if interested
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
  #79   Spotlight this post!
Unread 05-02-2014, 05:51
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I'm sharing three of 222's currently 3D printed parts on our 2014 robot that I feel will benefit other teams at this time.
A zip folder has been attached to this post and contains .stl, .ipt, and .stp file formats for each part. Two of the parts (.ipt format) have team #'s suppressed. If you want to add your own just unsuppress the text and modify as desired.
1: Nasson pressure switch mount.
Mount the mount as desired using the two holes. Once mounted clip in the switch. For extra security secure switch and wiring with ziptie.
2: VexPro 1x2" extrusion end cap.
3: Clippard air tank to VexPro 3 CIM ball shifter mount.
Mount two of these to the top of the 3 CIM ball shifters using 1/4-20 bolts. Insert tanks. Zipties may be used around the tanks to keep them from slipping back through the mounts easily.
For those wondering all of these parts were printed on Stratasys FDM 3D printers in ABS.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
  #80   Spotlight this post!
Unread 05-02-2014, 10:25
Ghost_Pack's Avatar
Ghost_Pack Ghost_Pack is offline
AKA: Peter S
FRC #0801 (Horsepower)
Ghost_Pack will become famous soon enough
I can attest to the strength of well designed PLA printed parts.
Team 801's prototyping division has made entire gearboxes before (with the exception of the gears, axels, and bearings) using a Replicator 2 at 20% infill. As far as I'm aware, we have yet to break any of our casings or mounts despite the 2 months of testing we out them through. Also, Children of the Swamp 3D printed their wheel mounts last year and I don't think they broke any mounts all season.
  #81   Spotlight this post!
Unread 06-02-2014, 08:36
pfreivald's Avatar
AKA: Patrick Freivald
I finally got around to uploading our Victor tower. Here it is:
http://www.thingiverse.com/thing:242644
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #82   Spotlight this post!
Unread 06-02-2014, 11:45
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
so spce is very limited on our robot this year for electronics. Saddly, we never purchased a 4 port cRIO so we are still stuck with same old long one. So to save space on the electonics, we are mounting our side car on top of the open ports on the cRIO. A 3D printed mount was created to hold in place on the cRIO. The part wasnt printed on a maker bot but on a larger, industrial printer.
  #83   Spotlight this post!
Unread 06-02-2014, 20:00
Alan2338's Avatar
Alan2338 Alan2338 is offline
Former Team Leader/Driver - Alumni
AKA: Alan Cabiness
FRC #2338 (Gear it Forward)
Alan2338 will become famous soon enough
We have printed a lot of 3d components for our bot so far, but one stands out as the coolest...
Here's a teaser of our coolest 3d printed part...
See if you can guess what it is!
Name:	2338 Print Teaser.jpg
2013 Wisconsin Regional Winners (111, 1732)-Midwest Regional Semifinalists, 2nd Seed Captain, (111, 1675), Gracious Professionalism
Galileo Division Quarterfinalists, 7th Seed Captain (2512, 1323)
2014 Crossroads -Quarterfinalist, 8th Seed Captain (4085, 2358)Midwest -Finalist, 2nd Seed Captain (1732, 3936)
2015 Wisconsin -Quarterfinalist, 2nd Seed Captain (2077, 167) Judge's Award Midwest-Finalist, 1st Seed Captain (1756, 171) Chairman's
Archimedes Division Winner, 1st Seed Alliance (1023, 3996, 1089) Einstein Semifinalists
DePaul Class of 2018 - Computer Science
  #84   Spotlight this post!
Unread 07-02-2014, 14:59
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Our team made a small 3d printed cam with a half inch hex center. We plan on using this to hit a limit switch once per revolution to tell us when our catapult has reset.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #85   Spotlight this post!
Unread 07-02-2014, 15:09
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Our current list of 3D printed parts include:
Spacers
2x1 End Caps
Catapult limit switch cam
E4P encoder mounts for WCP single speed shifters.
Camera Mount
Attempted fix to our button maker.
We are really liking the capability to make odd parts quickly and efficiently.
Team 4488 - Mentor 2013-2016
  #86   Spotlight this post!
Unread 07-02-2014, 15:48
Mr. Flaiz Mr. Flaiz is offline
FRC #0514
Mr. Flaiz is an unknown quantity at this point
Could someone post a picture of a 3d printed camera mount? Just looking for ideas.
Thanks
  #87   Spotlight this post!
Unread 09-02-2014, 18:39
AKA: Bradley Rigdon
Here's another part.
A VexPro 3 stage gear cover. It helps with safety and keeping the grease where it should be... It also keeps the electronics guys happy!
File is attached below in the .ipt, .stp, and .stl format.
You may need to change the design or length of the legs to account for your drive chain or belt. Also you can adjust the clips so they actually clip onto the rods if you wish, but it can be secured fine with a ziptie.
  #88   Spotlight this post!
Unread 09-02-2014, 18:48
AKA: Bradley Rigdon
Thanks
The 3D modeling isn't the best on this one. Also it hasn't been fully printed yet to confirm fitment. There is a 90% chance you will want to change the design anyway. It is designed for the Axis M1013.
The intent is to slide the camera in from the top and secure it using the rear integrated screw to pinch the plastic housings together with a nut.
I've attached a .stp and .ipt for you.
  #89   Spotlight this post!
Unread 20-02-2014, 01:45
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Thanks
This one is a bit complicated, the programming team requested the ability to rotate the camera 31 degrees to the right and left of center depending on which auto program we ran.
The part that holds the camera and blue part are 3D printed, the rest is common hardware except for a rather interesting part. http://screencloud.net/v/tAqD
http://screencloud.net/v/5Jhe
The small piece of what looks like threaded rod embedded in the clear part that holds the camera is a spring plunger. The blue block is bolted to the robot and has 3 indents in it, one for -31deg, one for looking forward and one for +31deg, as you rotate the mount about 4 inch 10-32 the spring plungers snap into the indents locking it in place.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
  #90   Spotlight this post!
Unread 20-02-2014, 09:10
maxinthemiddle's Avatar
maxinthemiddle maxinthemiddle is offline
AKA: MacKenzie
FRC #2399 (The Fighting Unicorns)
maxinthemiddle is an unknown quantity at this point
Seriously, when it comes to mounting encoders, using 3D printed parts saved a lot of time and effort. Another useful application is to cover print a part that can press into and cover the open end of conduit or other metal tubing.
