Go to Post The horse is dead; stop beating it please. - DonRotolo [more]
Unread 02-02-2014, 13:11
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Spikes are not working
Hi Chief Delphi,
We are having some problems with our spikes. Our spike is plugged into relay 8 on the digital sidecar, and we have the 12V and the GND prongs plugged into the power distribution board. The colour of the LED on the spike is orange. We also have a 20 amp breaker in the spike.
We used the following code to get the relay running.
Relay *compressor;
compressor = new Relay (8)
if(primaryController->GetRawButton(1)){
//primaryController is our joystick. Drive code works fine with this joystick.
compressor->Set(Relay::kForward);
else{
compressor->Set(Relay::kOff);
We have used the same code to get spikes running on robots a few months ago. We have also tried replacing "kForward" with "kReverse" and "kOff".
When I enable the robot, I press and hold the button to enable the spike, nothing happens. Also, we put a multimeter to the ground and signal ports on the digital sidecar and we did not get a voltage reading.
Our team is stumped at what is wrong. The wiring looks to be correct, and we know the code works since we have used the exact same code before.
We have tried this setup on two different robots, with two different power distribution boards, two different digital sidecars, multiple PWM cables and multiple spikes.
Any help would be greatly appreciated.
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
Unread 02-02-2014, 13:30
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
Re: Spikes are not working
Are you sure that the button you are pressing is button 1? Try printf on the button to figure out which button is 1.
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 02-02-2014, 13:53
I am sure that I am pressing the right button. I have used the same button to control many things in the past. Also, if I open up "Set up USB game controllers" in windows, when I press the button that I am pressing, button one is what illuminates.
Arzaan Khairulla
Programmer/Driver
Unread 02-02-2014, 14:08
Do you get any lights on the Digital Sidecar next to the relay pins?
Is the Digital Sidecar correctly powered, with battery voltage present on its power input and all three of the power LEDs brightly lit?
What pattern is the Robot Signal Light flashing when you have the robot enabled?
Unread 02-02-2014, 14:23
No, I do not get any lights on the digital sidecar next to the relay pins.
Also, the digital sidecar is correctly powered, we have nine victors on the robot which all work just fine.
The robot signal light flashes in its normal pattern, as if nothing were wrong with the robot.
Arzaan Khairulla
Programmer/Driver
Unread 02-02-2014, 15:30
You didn't quite answer all my questions, but I'll assume that your understanding of "correctly powered" and "normal pattern" is correct.
Where in your program is the code you showed us? It looks correct, but whether it will work depends on where it is placed. Give some larger context, please.
Unread 02-02-2014, 16:16
vgdude999 vgdude999 is offline
Programmer/Driver
FRC #1751 (Comsewogue Warriors)
vgdude999 is an unknown quantity at this point
Does the light on the spike change at all when you hit the button? If it doesn't, try with another PWM cable. Also try using a different port on the sidecar if you can.
2013: Rookie year, programmer-in-training; SBPLI Regional Finalists
2014: Co-Captain, Programmer, Driver; Seeded 15th
2015: Co-Captain, Programmer, Driver
Unread 02-02-2014, 16:27
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
What programming language are you using?
Unread 02-02-2014, 17:02
DonRotolo's Avatar
Back to humble
FRC #0832
vgdude999, If the status lights next to the relay ports are not lighting, the spike light and PWM cables are irrelevant...
Unread 02-02-2014, 17:17
parkedraccoon's Avatar
parkedraccoon parkedraccoon is offline
FRC #0766
Team Role: Electrical
parkedraccoon is on a distinguished road
I had a similar problem earlier this season. I tried switching the layout of cRIO modules, various different cRIOs. Eventually, I believe I finally fixed it by imaging the cRIO to the 2014 image. (Make sure you are also using the matching 2014 C++ installation, including the updated WPILib) Seems strange, but it seemed to fix the problem.
On a related note, you probably should have a pressure sensor to help switch the compressor on/off.
"Why is it stupid?"
2006-2008 Little brother of Team 766 member
2008 FLL
2009-2014 FRC 766
2014-> ??? (hopefully some sort of mentor!)
Unread 03-02-2014, 16:20
I imaged the cRio using the 2014 cRio imaging tool. (The cRio we are using is brand new). Is there any way to specifically use the 2014 image which I am missing?
Also, we were just testing the relay for the compressor, not the actual compressor itself which is why the pressure switch is missing.
Arzaan Khairulla
Programmer/Driver
Unread 03-02-2014, 17:26
The version 52 cRIO image will be available when you install the update for whatever language you are programming with.
Unread 03-02-2014, 19:36
FRC #0766
Updated WPILib Workbench update will provide you with the required v52 cRIO image (you clicked the 'format cRIO button right?) and should also extract the updated files for WindRiver to use. That seemed to fix when I was having the same problem.
"Why is it stupid?"
2008 FLL
2009-2014 FRC 766
Unread 04-02-2014, 12:23
We fixed our issue. Apparently, our ribbon cable was not held down with screws in the cRio, which resulted in not enough pressure being applied on the pins.
Thank you all for your help.
Arzaan Khairulla
Programmer/Driver
