Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
Unread 03-02-2014, 22:31
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
The SAM Thread
OK, I was excoriated for this suggestion in 2012, but was proven correct that it was possible and, apparently, reasonable. Can (and may) a robot interfere with a ball in flight by shooting a ball at it?
I'll give you the reality that there are only 10 seconds (generally) when more that two balls in play, so the strategic value of ack-ack is greatly reduced over Rebound Rumble. Is it worth interferrng?
Tim
Software Mentor
3853 Pridetronics[
Unread 03-02-2014, 22:57
Andrew Lawrence
Posts: n/a
Re: The SAM Thread
Is it possible? Yes. Is it worth attempting? No.
Unread 04-02-2014, 08:42
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: The SAM Thread
Check with PFreivald and 1551, they might have an interesting take on this
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 04-02-2014, 09:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: The SAM Thread
Best-case its a net-sum-zero strategy, so if it fits into your game plan it might be useful.
I cannot figure out how it would be genuinely useful though.
Unread 04-02-2014, 09:45
Re: The SAM Thread
Dodgeball immediately jumped to mind.
Unread 04-02-2014, 10:24
Joining the 900 Meme Team
FRC #0079
Re: The SAM Thread
Coming out ahead in auton and locking the score. Ranking suicide in quals but could be a useful strategy if you know you've got them in auton but they can cycle faster.
Unread 04-02-2014, 10:29
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: The SAM Thread
I suppose so. I guess I was assuming that if you were consistently winning auton (i.e. reliable high-goal shooting) that you would always wind up with better cycle scores.
Do you really think trying to hit a ball out of the air with another ball would be better than a 2 or 3 robot defensive blockade?
Unread 04-02-2014, 10:32
FRC #0079
Re: The SAM Thread
Not at all. Hitting a quickly moving target is NOT a trivial problem in the least.
You did ask for a case when it would make sense, not a case in which I would do it.
Unread 04-02-2014, 10:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: The SAM Thread
Touche good sir!
