Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 04-02-2014, 08:53
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
pic: Aztechs 157 Frame Sneak
Unread 04-02-2014, 08:57
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Aztechs 157 Frame Sneak
Very nice looking, any issues turning on carpet with the pneumatic wheels?
Unread 04-02-2014, 09:09
Senior Mentor/Coach
FRC #0157 (Aztechs)
We tested it and there didn't appear to be any issues but can switch out with different wheels if need be.
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 04-02-2014, 09:22
jkessler_22's Avatar
jkessler_22 jkessler_22 is offline
Motor Man
AKA: Joe Kessler
FRC #3015 (Ranger Robotics)
jkessler_22 is an unknown quantity at this point
Be sure to test it with the full anticipated weight and on carpet. I was on a team that was burned by this late revelation and we had a hopping bot once all the parts were attached. Needless to say, we had to change our wheels.
Good luck on the rest of your build !
Unread 04-02-2014, 09:24
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Did you try driving it on carpet weighed down to 120lbs?
If it doesn't turn, all hope isn't lost - you could change one end or both ends to a smoother tire with a less aggressive tread pattern.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 04-02-2014, 11:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Boy, I really hope that drivetrain is 8 CIMs/mini-CIMs. That would be sweet.
