Go to Post Judging the Championship CA must be the hardest thing to do in FIRST. I'd rather try to stop an alliance of 1114, 111, and 25 from scoring 3 pointers than to judge the CA between these teams. - Andy Baker [more]
Unread 04-02-2014, 13:14
muaddib42 muaddib42 is offline
FRC #3128
muaddib42 is an unknown quantity at this point
Motor controlled by Talon won't turn off
I have been programming our robot with Java and for some reason when I set the motor power to 0, the motor continuously spins. I am not sure why. If anyone has any ideas that would be very helpful.
Unread 04-02-2014, 13:17
Re: Motor controlled by Talon won't turn off
It's because it's still getting power
But seriously, you need to provide more detail.
Maybe post your code.
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Does it still run when the robot is disabled??
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 04-02-2014, 13:20
FRC #3128
Nope. When I run talon.get() it also returns 0.
Unread 04-02-2014, 13:21
FRC #3128
The relevant block of code is here:
public void stopSpeedControl() {
DebugLog.log(DebugLog.LVL_DEBUG, this, "Talon GET: "+this.talon.get());
this.talon.set(0);
this.spdControl.cancelEvent();
this.spdControlEnabled = false;
I have confirmed that it has entered this block of code.
Unread 04-02-2014, 13:24
There may be other code which is turning it back on.
Unread 04-02-2014, 13:33
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Is the motor spinning 100% speed or just slow? If they're going 100%, its probably code, which is outside my knowledge range.
If they're just spinning slow or pulsing, I'd recommend doing a calibration of the Talons. The calibration procedure can be found on page 7 of http://crosstheroadelectronics.com/T...Manual_1_2.pdf
